Question before purchasing tires - help
Old Mar 30, 2016 | 11:00 AM
Jose2SS's Avatar
Jose2SS
Default Question before purchasing tires - help
Good morning, I am about to purchase new Michelin tires for my 2005 C6, it's a 1SB. Can I go with the following sizes without problems:
Front 255-40-18
Rear 305-35-19
Let me know, also, if I can go wider too. Please educate me here.
Thanks!!!!
Old Mar 30, 2016 | 01:44 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Front 255-40-18
Rear 305-35-19
Thanks!!!!
The factory sizes for an '05 C6 are 245/40-18 (F) & 285/35-19 (R), so you are already going wider. To convert "section width" from mm to inches, divide by 25.4. Thus the stock tire widths are 9.6" (F) & 11.2" (R) and the wider tires are 10.0" (F) & 12.0" (R). Difference is 0.4" (F) & 0.8" (R) which should not create a clearance problem.
Old Mar 30, 2016 | 02:32 PM
Jose2SS's Avatar
Jose2SS
Super!!!! Thanks for the information!!! will proceed with the purchase then.
Old Mar 30, 2016 | 04:30 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
I was told years ago the for every 10 you go wider u should go 5 shorter sidewall to keep tire close to same diameter.
Robin
I would check with tire rack about plus sizing first.
Old Mar 30, 2016 | 04:59 PM
tc_rain's Avatar
tc_rain
I currently run these Invo Nittos on my base C6 without any issues. These came on the car when I got it. I will need to replace them this year and will most likely go with the same.
Rear 305/30-19
Front 255/40-18
To Question before purchasing tires - help
