C6 Black Headlights
Thanks a bunch!
The hardest part of the whole thing is removing the headlights from the car. If you don't want to it yourself, RLSebring will paint your bezels, and install new lenses far cheaper than you can buy a used set that likely will need new lenses anyway.
There is a Headlight post above the C6 Corvette General section.
Robert is a great person, and is very knowledgeable about anything headlights.
I have instructions with pics on how to do that without removing the bumper, just loosening the fender bolts and top part of the bumper facia.
www.corvette recycling is one place that I know of that might have a black set.
Google Corvette salvage yards, and you will get many hits I'm sure.
I removed my lenses and painted my bezels black a few years ago. It was really quite easy to do.
I have really thought about doing that but I fear that I will get aggravated and break something. I always have seen with headlights that are opened up they never seal back right. I have seen his page on ebay though, seems like he is a nice guy.
The PL Construction adhesive works well to reseal the lens. As an extra precaution against any sealing issue, I ran a bead of clear silicone sealant around the perimeter where the glue and lens join at the assembly.
All that is hidden by the rubber gasket that goes around the headlight.
I've had zero issues since I did mine.
It's funny really, because when I got the car, the passenger side would fog up from time to time, so I really didn't pay that much attention to it. Just thought that was the nature of the beast.
When I removed my original lenses, the passenger lens was able to be removed without even heating it up by the oven. Once I pried back the clips, I was able to easily remove the lens.
The OEM adhesive had not cure properly, so in reality, the lens had no sealing.
The driver lens was adhered correctly, because I had to heat it a few cycles before I was able to pry it off the assembly.
Good Luck, in whatever you decide to do.
Thank you.
See the headlight removal and lens replacement instructions at www.c6c7vette.com 1000's over the past 10+ years have followed my instructions for a perfect job.
If I do your lights they are always did for the price quoted and in the time stated. I don't have to dream up excuses for being late as they are always right on time and money.
