Differential oil
Old Apr 17, 2016 | 08:45 PM
mracer's Avatar
mracer
I had the rear end "clunk" changed it with the GM Dexron LS and all is good!
Mike
Old Apr 18, 2016 | 09:25 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
So, did you use the GM LS oil that doesn't need any added friction modifier and seems to work well for everyone who has tried it or did you go with something else?
And how did you "smoke" the rearend? I've not seen anyone do that before. Breaking the 2005 with massive hp enhancement is known but not "smoking" one.
Old Apr 18, 2016 | 10:30 AM
windyC6's Avatar
windyC6
Originally Posted by LowRyter
so it's normal to have the rear ticking in the parking lot because the rear end fluid is cold? even after a 3 hour drive?
I didn't know that. Perhaps I wasted by $$ changing it? But it doesn't tick anymore.
Your on your own with that one. My post was in reference to the post someone left suggesting that you should heat the fluid up by cutting figure 8's in a parking lot somewhere. Thats just wrong as you need to get those gears spinning pretty fast to heat that fluid up.
Old Apr 18, 2016 | 08:38 PM
LowRyter's Avatar
LowRyter
OK, gotcha
thnx
Old Apr 23, 2016 | 04:22 PM
Bluevet2006's Avatar
Bluevet2006
Default Term
Just used that term. Drag racer it a lot and that killed the posi. The oil I used syn 75-90 GM with GM modifier and it's doing great with the new treat end
Bluevet2006
Originally Posted by Rogers 07
Important: DO NOT add any limited-slip additive (friction modifier). With this new fluid (Dexron LS Gear Oil 75W-90) it is no longer required to add a friction modifier. If a friction modifier is added, it will cause the fluid to lose some of it's friction reducing properties as well as reducing seal life.
Fill the differential with the new DEXRON® LS gear oil, P/N 88862624 (Canadian P/N 88862625). Refer to the table listed below for lubrication specifications.
Check the fluid level to ensure it is even with the bottom of the fill plug hole to no lower than 6 mm (0.25 in) below the opening. Install the fill plug and washer to the differential. Tighten the differential fill plug to 35 N•m (26 lb ft).
Important: Steps 8-13 are for vehicles equipped with the differential cooling system. For vehicles not equipped with the cooling system, proceed to step 14.
Raise the vehicle so the wheels are about a foot off the floor. Make sure the wheels can spin freely without obstruction from the hoist or any nearby items. Start the vehicle and put the transmission in second gear. Slowly accelerate to 10 mph and hold this speed for one minute. Turn the vehicle off. Raise the vehicle. Check the fluid level in the differential. Add fluid until the recommended level is reached. Lower the vehicle.
Once the differential fluid has been changed, the vehicle must be driven in 8-10 tight figure eight maneuvers to heat the fluid and allow the fluid to be worked into the clutch plates.
Lubrication Specifications Application
2004-2005 XLR (Including Export) and 2005 Corvette (Non Export)
1.72 liters
1.85 quarts
2006-2008 XLR (Including V-Series and Export) and 2006-2008 Corvette (Non Z06)(Non Export)
2.0 liters
2.11 quarts
2005 Corvette Export
1.88 liters
1.99 quarts
2006-2008 Corvette Export (Non Z06)
2.16 liters
2.28 quarts
2006-2008 Corvette Z06
2.75 liters
2.91 quarts
Parts Information:
Description: DEXRON® LS Gear Oil
Part Numbers:
88862624 (US-1 Quart)
88862625 (Canada-1 Liter)
Old Apr 23, 2016 | 04:23 PM
Bluevet2006
Originally Posted by lavla
I changed the differential fluid in my 2005 coupe twice during the time I owned it (4k to 60k miles) with Amsoil 75/90 gear oil. I was experiencing "clunking" when I drove in reverse and turned the car. Once I replaced the fluid, all the noise disappeared.
I just had the oil and differential fluid changed in my 2013 Grand Sport after making the drive back to NJ from FL. The car had no issues but I changed the differential fluid just for the heck of it.
I have to say, the car has been bullet proof!
Old Apr 23, 2016 | 08:33 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Originally Posted by Absolutevil
I changed mine out with Mobil1 LS formula. I changed it right before I made a trip to Florida and after over 2k miles so far it's quiet. I'll see what happens as the miles pile up but for about ten bucks a bottle I'm happy.
Mine had limited slip clutch chatter until I replaced the fluid with Mobil LS fluid and it has been great since, now over 93,000 miles. Easy job.
Old Jul 18, 2016 | 12:16 PM
Avcrest's Avatar
Avcrest
Cruising
Default Mobile1 LS
Thanks. I just put 2 quarts of Mobile1 LS $20 in my 07. I bought the little hand pump too $9 which made it easy. No more clanking, drives smooth.
Old Jul 18, 2016 | 05:45 PM
Red08's Avatar
Red08
Originally Posted by simplegto
GM Dexron LS is the best oil I have found and it needs no FM.
I changed mine out a couple of years ago. It maybe didn't need it, but I went ahead for peace of mind. I used the GM brand. I emptied exactly two quarts, and refilled with two quarts.
Old Jul 18, 2016 | 09:01 PM
CMY SIX's Avatar
CMY SIX
I had Amsoil in for a few years POP came back, put royal purple in quite again
