2006 electrical power question
Old Apr 13, 2016 | 11:18 AM
webdzynes's Avatar
webdzynes
Default 2006 electrical power question
I have a 2006 and want to simply install a jl audio amp. (I replaced the door speakers with some DynAudio's but they are too hard to push with the stock head unit.) Since my the center console plug stopped working a few years ago and I was never able to trace down the problem, I cannot use that always on option. So, heres the question -
Is there an always on AND an ignition only on available anywhere in the back that I can tap into for amp power? I dont want to mess with the fuse box or running up through the firewall. Just something simple as I wont be keeping the car after this summer...
Old Apr 13, 2016 | 11:43 AM
EVRose's Avatar
EVRose
If you try to power an aftermarket amp with any factory wires you'll more than likely start blowing fuses. It is not advisable.
Old Apr 13, 2016 | 12:23 PM
webdzynes's Avatar
webdzynes
Thanks, but its worth a shot. If I blow fuses I can always look for another alternative. I wont be running it super loud or have subs to power so it shouldnt be to big a draw... But thank you...
To 2006 electrical power question
