Hey all. Just curious about something. I repainted my calipers today on my 2006 Base. I wanted to take them off the car for the paint job. The caliper bolts turn but don't appear to be backing out at all. I tried both sides on the rear and same result. So I just removed the bracket bolts and did it that way. I've done brake jobs before but this is a first. Am I missing something??? Thanks for any help
If you look closely at the other side of the bracket right against the rubber dust cover you will see a flat spot or another "nut" on the caliper slide pin... Put a wrench or crescent on this as you turn the bolt and it will come out... Otherwise you are just turning the bolt AND the sliding pin at the same time
Tyler
If you look closely at the other side of the bracket you will see a flat spot on the caliper slide pin... Put a wrench or crescent on this as you turn the bolt and it will come out... Otherwise you are just turning the bolt AND the sliding pin at the same time
Tyler
Oh snap! My Instagram friend. This is dr.wiebel Lol. Nice to see you here on the forum. Yeah now that I think about it I did see that. Didn't think about it tho lol. Thanks man
Ha ha nice! I had no idea that was you when I posted! Great to see you on here as well!
