need low profile jack
http://www.harborfreight.com/3-ton-l...ump-61282.html
http://www.harborfreight.com/2-ton-L...ump-60678.html
It gets under the back with a cradle I made to lift on points recommended but the front still needs to be on my home made ramps to get the cradle and jack under the car
Cons on a low car no doubt
NSF
http://www.harborfreight.com/2-ton-a...ump-62247.html
Nice ramps NSF.
It may sound like common sense, but regardless of the jack you get, never ever get under a Vette without jack stands.
NSF
http://www.harborfreight.com/2-ton-L...ump-68050.html
I picked up a 1& 1/5 ton from HF.
It worked fine to lift the car a few inches to put blocks under the wheels prior to using the EZ car lift.
$60 with the coupon and I was able to share another coupon with a fellow in line.
I also have the Harbor Freight 2 ton steel low profile jack ( 60678 or 68050 ) for $139, and the crossbeam ($31).
But obviously there is not enough clearance in the front of the Grand Sport to get it under the front splitter or air dam.
Rather than build my own wooden ramps like NSF, I bought a great set of "mini ramps" designed simply to lift a low car enough to get a jack underneath. These ramps, called TRAK-JAX, are made by Race Ramps.
They are only 3" high, but when the Grand Sport is on them the splitter is over 6" off the ground, enough to slide almost any jack underneath. Addtionally, these ramps weigh less than 2 pounds, take up essentially no space in the garage, and even fit in the hatch of the Vette.
Driving up onto these low ramps in the Grand Sport is barely noticeable until the tire hits the stop on the ramp. My splitter once scraped for a second at the bottom of the ramp, no more than my driveway, but this only happened in one sloped area of my garage floor.
I paid about $85 for the TRAK-JAX . . . a little pricey, but the wood to build my own ramps at Home Depot was almost $50.
My system is to drive up onto the TRAK-JAX, slide the Harbor Freight jack (with crossbeam) under the car, lift it by the front crossmember, and then take the TRAK- JAX out. I then either use jack stands, or for oil changes, I place my higher Rhino Ramps under the wheels and lower the car back down.
I then take the jack away and change the oil. Then I put the jack back, raise the car, slide the Rhino Ramps out and put the TRAK-JAX back under the front wheels. I slowly lower the car back onto these ramps, take the jack away, and back the car off the mini ramps. The whole process takes about at long as it took me to type this post.
I also have the hockey pucks for lifting from the side, but I prefer the car on ramps.
I do not work for Race Ramps, but I am extremely pleased with their TRAK-JAX mini ramps . . . I highly highly recommend them. Good luck.
1) The stops are not very substantial and can easily be overridden.
2) The stops decrease the area size of the ramp platform.
3) When lowering the car back down onto the ramps it's easy to misjudge the placement of the ramps and damage the stop if the tire contacts the stop before the platform.
If you are not comfortable judging the position of your tires when driving up the ramps you can place a wheel chock in the path of the rear tire so that the tire contacts the wheel chock when the front tires are centered on the platform.
https://www.reverselogic.us/jack-assist-ramps.html
They are only 4" high, but when the Grand Sport is on them the splitter is almost 6" off the ground, enough to slide almost any jack underneath. Addtionally, these ramps weigh less than 2 pounds, take up essentially no space in the garage, and even fit in the hatch of the Vette.
Driving up onto these low ramps in the Grand Sport is barely noticeable until the tire hits the stop on the ramp. My splitter once scraped for a second at the bottom of the ramp, no more than my driveway, but this only happened in one sloped area of my garage floor...
http://www.reverselogic.us/jack-assist-ramps.html
Additionally, although I did not post this detail, once the car is on the Trak Jax I actually mark the position of the mini ramp on my garage floor with a pencil. I then also place chocks on the rear wheels. Then when its time to lower the car back onto the ramps I simply place the Trak Jax back where my pencil lines are located. Has worked perfectly so far (only 3 oil changes).
So my "system" is working fine for me . . . but as you are an expert in these ramps I appreciate your insight. Great product for sure !!
