I have a 2010 with bose nav unit. Often takes 2-3 insertions to get CD recognized. I believe the issue is dirt. We drive a great deal with top down.
Last year I approached a good audio shop who said the unit could only be dealt with by GM dealer. Dealer booked appointment with outside firm used by local GM dealers. Received a call - need new unit $2400.
I declined and I picked up car. I tried a CD - worked perfectly and kept working all last fall. I believe the outside firm removed the unit and got some dirt out. When they re-installed it nothing work immediately and so they thought unit was dead.
It could well be dirt/dust on the laser lens of the CD player. Did you try blowing air in a can into the slot, or trying a CD cleaning disc with the small brushes on the cleaning CD, and solution to clean the lens?
Mine was acting up, I used both and no issues since.
When and if mine goes down, I'll just buy a good used Nav unit from a newer model. There are lot's of them sitting because many have replaced with aftermarket units.
I use the OEM Nav, have the most recent 2016 map DVD, so I will stay with the OEM.
Two years ago, we could not find any supplies for sale in Canada and ordered a cleaning disc on line for my wife's Honda. Unfortunately it did not work.
Any info you have on the disc and cleaner would be very helpful.
Thanks.
I bought the one I used from "The Great Canadian Dollar Store". Between that and the compressed air in a can, it may just clean it up again.
Ideally, it would be nice to be able to take the player apart and clean it by hand, but it's not easy to take apart, if even possible without breaking something.
A cleaning CD with brushes that will clean the laser unit.
People still use CD's? Get an iPod, run an aux rca jack from the rear of the head unit into the glove box, bam. No moving parts, no lasers to get dusty, no "read errors," no skipping due to scratches, no hauling around a huge binder full of cd's, etc.
Or better yet, replace the Corvette's archaic head unit with a unit that was actually designed in the 21st century and stream music wirelessly via Bluetooth-- side bonus, more customizable sound tuning, navigation that doesn't require a physical disc (that media is dead) and actually works.
Blowing compressed air in the slot is a easy way to clean the outside of the lens, but if the dust is on the bottom on the lens, or down in the lens refraction mirrors, then you have to pull the lens assembly protective cover off the laser to get that far down to blow the dust out of there isntead.
People still use iPod? Flash drive is the way to go, right in the USB port. Sounds incredible.
Sure, that works too, or a phone, or even just an SD card. My Kenwood unit could receive up to 128gb micro sd. There are so many better options than keeping the ridiculous factory head unit in working order after it's starting to show its age.
Just an update. Had to order cleaner CD from Amazon as none were available locally. Cleaning took 30 seconds and CD now works perfectly. Sure beats $2200 dealer wanted.
Dano,
Have you ever had a Nav unit apart to clean the laser and mirrors? I'd love to do that just to get it clean as per when new.
Yeah, but with the dealer you could be sure you were being professionally screwed. What charlatans these people are. They should be prosecuted for that level of dishonesty.
Dealers have no expertise with car audio systems...they almost always farm out these repairs, just like upholstery. They would normally just take whatever action is called for by the audio shop that did the diagnosis. There's no reason to think that they were knowingly trying to be dishonest.
Which cd cleaner did you get on Amazon? I ask because I got one from Walmart a few years ago and it only worked for a short period of time. I need to try a different one to see if it works any better.
