Map Lights staying on?
Old Apr 24, 2016 | 12:01 AM
jshot00's Avatar
jshot00
Default Map Lights staying on?
Changed to LED on the map lights and after closing doors, the light time out and go down to a very dim display! is this normal when you have the LED lights??
Old Apr 24, 2016 | 12:03 AM
Iconic's Avatar
Iconic
Miller Time Wisconsin 🍺
2021 C7 of the Year - Modified Finalist
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13 thru '22
The same thing happened to me years ago. I started a thread and others chimed in with the same results.
Old Apr 24, 2016 | 10:02 AM
4SUMERZ's Avatar
4SUMERZ
That is the downside of LED's on the interior lights. Not all will completely go out.
Old Apr 24, 2016 | 10:07 AM
promocop's Avatar
promocop
Then why bother changing them out?
Old Apr 24, 2016 | 11:00 AM
cclive's Avatar
cclive
Bingo....
Old Apr 24, 2016 | 01:08 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default map lights staying on
This works for some applications. Take the map light LED bulbs out and insert both of the old 194's. Close the doors with you inside the car and then remove both stock bulbs after they time out. Insert both LED bulbs without turning them on. Luck maybe on your side installing them in the correct way as some bulbs only work when installed that way. Open the door and close with you still in the car and see what happens. If this does not fix the problem you will have to try some bit more expensive LED 194 bulbs. Ask me how I know this. Good Luck
Old Apr 24, 2016 | 03:45 PM
icyteddy's Avatar
icyteddy
I am a little confused. I swapped out ALL my stock interiors bulbs with white LEDs and they turn off after a few seconds of closing the door. Also, OP did you try the light ****. The one you can dim the interior lights? Or is this something else?
Old Apr 24, 2016 | 06:38 PM
2008 Corvette
Default Led's
The map lights time out and stay on very dim. This is sometimes caused by the installation procedure or the quality of the 194 LED bulbs used.
Old Apr 25, 2016 | 07:21 AM
jshot00's Avatar
jshot00
Thanks i will Try that
Old Apr 25, 2016 | 05:30 PM
jshot00's Avatar
jshot00
would this be a big concern for the battery?
Old Apr 25, 2016 | 06:04 PM
2008 Corvette
Maybe. Try what I suggested first.
Old Apr 25, 2016 | 06:46 PM
cclive's Avatar
cclive
This would be a time to measure the draw from the battery after the computers settle down.
To Map Lights staying on?
