Odd circumstance..........
Received 3,652 Likes
2016 C6 of Year Finalist
And not being driven that much over those years,means it hasn't been charged much by the alternator. Do yourself a favor,don't charge the old one,replace it with a new one,before your out on a road trip and get stranded at a place like Bates Motel.
Bruze (05-06-2016)
Received 1,136 Likes
And at that point, simply recharging it won't reverse the damage.
How much will the battery be weakened -- even though it is "fully charged?" Maybe enough to give the (especially the C6) electrical system diarrhea.
The chemistry of a normal lead acid car battery is such that it does best when it is stored at a full charge. This is just chemistry. The vast majority of cars out there are driven every day or at least every second day. This usage in itself means that most batteries are kept at a full charge. Leaving the Vette to sit for a couple of weeks at a time will mean that while not dead, the battery is spending much of its' time in a less-than-full charge condition. This somewhat shortens the life, even though the battery may always have enough oomph to start the car. This is the reason for a battery tender to be on the battery all the time.
In contrast, a lithium ion battery like those in a laptop computer are best stored at a 50% level of charge...this produces the best long term health for them. Not all batteries are best left at a full charge, but a regular car battery is.
The way I figure it, if I keep charging it, I can probably get it to last at least another 5-6 years.Maybe more.
I would opt to replace the battery BEFORE I get stranded. It's a lot cheaper that way.
At any rate, as has been posted here a zillion times, if you want to take the guess work out, get it load tested (at nearly anyplace that sells batteries).
I'm just pulling yer guys legs.
I checked it with a hydrometer this morning and all of the cells were even, but they all read right on the fair/bad line. It's been charging for two days (after I charged it Sunday). And after I charged it with my big charger all morning, it still read the same. So it wasn't talking a charge. It started right up fine all along. I never had any problems with it except for the hood light not coming on. Which I guess isn't supposed to work that way anyway.
So I went down and got a new battery. The new one charges about 14.2 with the AC, lights and everything on, so it carries the load pretty good. Thanks for all your help.
Sorry I teased you guys a little with my joke. I couldn't resist.
