What did you do to your C6 this weekend?
#2961
Finally got snow here in NE Ohio. Oil change, left it on jacks and pulled the wheels off, hardwired the tender to the jump box location under the hood and put on tender.
Hopefully a whole mess of little projects before spring, just need to find the time.
#2964
#2965
#2966
I’ve been working on installing new Holley valve covers and re taping everything and tucking everything away cleaning up the top of the motor while it’s raining. Still have a lot to do.
Have to find an old set of FRC to cut and paint. Have the coils repainted
But this is it so far. Long way to go.
The valve covers are satin black
ptroxx (01-16-2019)
#2968
Not this weekend, but I copied a bunch of photos from my wife's phone to mine and found this shot she took when I was doing my brakes a while back.
New rotors and pads all the way around my 2008 (Z51).
myredhead1 (01-19-2019)
#2970
Did the Ranger method on my clutch fluid. I have a turkey baster but was afraid the fluid would come back out too easily due to the fairly large diameter hole, so a few weeks ago I ordered a couple of 100ml syringes which worked perfectly. Nice clear fluid now and the clutch stroke both down and back up does seem smoother. Brake bleed will be next...
#2974
New radio
On Saturday, i finally installed my new Kenwood 9903S in my 13 GS. Bought the radio back summer of 2017...
And today, I finished up the rear view camera.
Hope to wash soon and then do front camera next weekend.
#2975
I replaced my tensioner pulleys and idler pulleys and belts.
I have read several times on here that GM put very little grease in the factory installed parts so I replaced them as a preventative measure.
The main belt tensioner pulley had a black powder falling out of it when I set it down on my work bench so I have to assume something was wearing out in there.
Easy DIY.
FYI, Rock Auto was almost half price for OEM parts (compared to buying them on Amazon or Auto Zone). Ordered the parts on Wednesday and they were delivered on Friday.
Easy DIY.
hmmmm16417 (01-21-2019)
#2978
looks like you have TWO sets of back up lines. there should be an option in the head unit to turn one set off. if not, you can snip the one little wire on your camera. unless you actually WANT both sets of lines ?
#2979
thanks. Read both manuals and seems I have both radio and camera lines turned on. Any recommendation on which one to leave on?
#2980
maybe they it both ways to see what you like better
