Greetings. Just got my '07 C6 w/30k mi. back from the dealership, after a HB replacement, belts, allignment and everything else. It was chirping last week, and through a search on this forum, I was able to determine quickly what it was. Thanks forum! Anyway, It was a $1265 job. I bought the car nearly 5 months ago, and they had no obligation to me for this repair. They covered $1000 and I paid the $265. They admitted that this was a common problem. Sounds like I got a good dealer. My question is: Has there been any updates over the past years to keep this from happening again? (i.e. updated or redesigned part) Or did they most likely, replace it with identical parts? Why the four-wheel allignment?
thanks..
sean
just had mine done and the parts dept told the service advisor that it was the newer part number ... don't know what that means but ....
if it goes again in the next 4 years they will be getting it right back as I have the extended warranty
A GM dealer likely replaced it with a GM part so another failure is more likely than if a higher quality aftermarket part was installed.
A balancer swap requires moving the rack and pinion and/or dropping the engine cradle. Either task can, but not necessarily, disturb the alignment settings. I think most don't get an alignment afterwards but is good if you can get it.
Agreed but as long as they are paying for it ...
When they did mine they did align it which I did not think about it until I read the service paperwork that listed the work that was done
Dave
There is a new part number but the GM balancer they just installed is the same design as the one that was going bad on your car. For $265.00, I would have let them install the same GM balancer again as well. I had to pay for mine so I installed an ATI. My 2007 needed it at 25,000 miles.
as I posted earlier my HB went at 106K the dealer replaced it with a GM part but they guaranteed it parts and labor for life and aftermarket part would only have a year guarantee and not labor so I am not worried
As I have stated many times this is just becoming more and more prominent. Even on this small forum which makes me wonder the percentage of HB failures thru out the nation of all Corvette's.
This is a big deal IMHO and GM should address it, but yet I realize they will never do it, sad
NSF
NSF
GM doesnt address anything I also have an 08 Suburban the dash boards crack on them I had one replaced by the dealer at no cost but now the replacement has cracked and I am on my on Customer service acts like they will help but its the same ole BS from GM sorry you are screwed Some dealers take care of you but others you are on your own. Its definitely a design flaw but GM will not help as with HB's
Thanks for the replies. My dealer did treat me right. I'd had the car for 5 months, but only put a few hundred miles on it. They probably took that into consideration. This is my first GM / Vette in 15 years. (Had a super low-mile clean C4 in '01) I'v always had a German car for a weekend toy since. The HB is a minor inconvenience compared to some of the scary Porsche issues I read about every day, for 8+ years. Google... "IMS failure". That's all you need to type. It's an issue that Porsche still refuses to own up to.
I thought I'd take a shot so I called the local Chevy dealer, asked the service advisor if they knew of or had any kind of program concerning the HB wobble problem, great, I already knew but what the hell worth a shot right.
So I asked and reply "Huh" uh no we don't know NOTHING about that nor do we have any replacement program. You could try calling General Motors and see what they say
So I expected a different answer
I just figure when the time comes I'll go with Powerbond or ATI as recommended, have one of the local independent shops do it
NSF
