Telescopic steering problem
Old May 11, 2016 | 10:13 PM
Midlife08's Avatar
Midlife08
4th Gear
Default Telescopic steering problem
I recently replaced the factory stereo unit, in my 08 c6, now the telescopic steering doesn't work? Everything else works as it should, any suggestions?
Old May 11, 2016 | 10:42 PM
cforcht's Avatar
cforcht
dont know if its related or not. but mine quit working one day. turned out the connector under the drivers seat came un-connected. plugged it back in and it worked again.
Old May 11, 2016 | 10:46 PM
Midlife08's Avatar
Midlife08
4th Gear
Thx, I'll check, although they didn't mess with the seat during stereo install, but..stranger things have happened !
Old May 12, 2016 | 12:13 AM
Konadog06's Avatar
Konadog06
If you were in under the steering column, beneath the trim or plastic panel in that area, you may have inadvertently knocked something loose. There is a motor unit about midway to the firewall in the immediate area of the column that drives a cable to I believe a gear drive back up towards the wheel. Look that the motors power plug has not come loose and that both ends of that drive cable at least appear to be engaged. To see this likely both of those trim pieces under there will need to come out, and a mirror might come in handy. Short of something obvious, the column drive motor and or cable connection would have to be looked at closer.
If you go to one of the GM online parts sellers parts illustrations, it may help some.
Bill
FL
Old May 12, 2016 | 09:51 AM
Konadog06's Avatar
Konadog06
Happen to have this handy, for I.D.
Pic of telescopic steering motor.
Bill
FL
To Telescopic steering problem
