Oil temp sensor question
Old May 15, 2016 | 09:14 AM
ray_ray's Avatar
ray_ray
Default Oil temp sensor question
When replacing do i need to drain the oil? Thanks everyone..
Old May 15, 2016 | 11:00 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
No.
Old May 15, 2016 | 12:07 PM
ray_ray's Avatar
ray_ray
Thank you
Old May 15, 2016 | 04:14 PM
C6topless's Avatar
C6topless
it is located on the top / back of your engine .. so you do not need to drain any oil
Old May 15, 2016 | 04:36 PM
RicK T's Avatar
RicK T
Umm.......he's asking about the TEMP sensor, not the pressure sender.
The TEMP sensor is in the oil pan, passenger side rear. Here's a post with a graphic:
https://www.corvetteforum.com/forums...and-girls.html
Old May 15, 2016 | 06:51 PM
cclive's Avatar
cclive
I was thinking the same. While it could be replaced quickly so as not to lose too much oil, some will be lost and alot would be lost if the oil was hot because the hot oil would keep fingers from putting the new sensor back in. The sensor is in the oil, in the pan.
Old May 15, 2016 | 06:55 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Assuming it wasn't hot, very little oil would be lost swapping it quickly. I would just check the level after.
Old May 15, 2016 | 07:36 PM
ray_ray's Avatar
ray_ray
Thanks everyone i will try without draining the oil.
To Oil temp sensor question
