Certified Pre-Owned problems
I bought my first real sports car last week! It's a '12 coupe. It's more than powerful to me, and looks beautiful. The forum has been great to learn more about the car. I have an issue, and wanted opinions from you all. Will use bullet points to keep it short:
-Certified pre-owned '12 coupe purchased from GM dealership
-Purchased the car last week
-There were a couple of minor issues which have been addressed (bad seal around headlamp, and molding around real wheels falling off)
-Within 36 hours of purchase, I noticed the steering shakes bad over 80 MPH, and contacted the dealership. The sales manager said the issue would be addressed and not to worry
-Car was dropped off yesterday, got it back today. The advisor called me and said the balance was off on the front tires, which they resolved. He said to come pick up the car, but stated he didn't know if the steering shake issue was resolved
-After driving home, I noticed the steering still shakes. I checked the invoice and noticed the comments for the road force reading was in the 20-25 range for both front tires.
-After reading posts here, I realized that was not in an acceptable range.
-I called the service department, the advisor was gone, but spoke to the foreman. He stated the reading was out of spec for the car. I asked why the advisor didn't notify me of this, when it seems to be an obvious problem. It came close to hearing excuses, but that quickly ended.
-Apparently the car became CPO months ago, and not necessarily when I signed the papers. He said he would have to speak to the sales manager again. It sounds like changing the tires are the fix, but the sales manager is not willing to address it.
-I purchased a CPO because I thought GM would stand by their product. I understand maintenance costs associated with sports cars, but to purchase a car that needs repairs before it's off the lot seems ridiculous to me.
-Any suggestions? Am I wrong to expect GM to sell me a CPO car that is stable at normal freeway speeds the day I drive it off the lot?
Looking forward to the good, bad, and ugly comments!
Thanks ahead of time!
For clarification, I am by no means an automotive expert in any way.
Here is part of that CPO inspection:
WHEEL AND TIRE CONDITION (INSPECT PRE-TEST DRIVE AND IN SERVICE BAY)
113. Tires meet 4/32" minimum requirement.
114. Wheel covers/wheel centre hubs OK (if equipped).
115. Tire side walls, valve stems, and wear pattern.
116. Tire size/correct air pressure/lug nuts secured.
117. Inspect wheel rims for damage.
During the test drive.
SUSPENSION/DRIVETRAIN/NOISE/VIBRATION/HARSHNESS
130. No abnormal vehicle noise, vibrations or harshness identified.
http://www.gmcertified.com/PDFs/Cert...st_02_2016.pdf
http://apps.gm.ca/app/GMCanada/Certi...ear~1111~make~
There are plenty of good used C6s w/o problems coming out of the gate to be had.
It may be nothing, or it may be something in which you are ultimately holding the bag.
I know if the Road Force Tech is good, they can get tires balanced with minimal weights by shifting the tire on the rim until he can get it no better. It takes time, so the tech has to be in no hurry.
Good luck
They usually respond and say they are so sooooooosssoooooory to hear of this and they will put you in touch with your local dealer to remedy this toot sweet,
And that's it.
My advice is to be consistently polite, but persistent. And you may need to be persistent. If things get really bad ... well, ask me later.
Disclaimer: I work for a dealership (not Chevrolet).
ETA, if you financed the car, you can also be persistent and polite with the finance manager (they also get a commission).
