battery change on 2012 base model
Old 05-24-2016, 03:18 PM
b09676
b09676's Avatar
Default battery change on 2012 base model
Dead this morning but I do have the tender hooked up and will give it a day or so to see if I can at least start it to take it up to the dealership.
If no start - anything special I need to know about replacing it?
I know to be careful with the conical nuts and to reindex windows, etc.
Also, any trick to loosening and taking out the hold down clamp bolt?
Will do this tomorrow so any advice today is appreciated.
Oh, maybe I'll check some you tube videos as well.
thx in advance
Old 05-24-2016, 03:33 PM
RicK T
RicK T's Avatar
When you go after the clamp hold down bolt, make sure your socket is securely attached to your ratchet extension. Mine wasn't, and I never found it.
The conical nuts don't have to come off, just loosen them and wiggle the clamps off.
Other than that, it's pretty basic and easy. Just common sense and take your time.
Old 05-24-2016, 03:39 PM
b09676
b09676's Avatar
Thanks Rick, appreciate your quick response.
Old 05-24-2016, 03:52 PM
BigMonkey73
BigMonkey73's Avatar
St. Jude Donor '15
OEM Battery terminals suck bawls. I replaced with these thanks to another forum member's suggestion:
Amazon.com: Scosche EBT Battery Terminal with ABS Cover: Car Electronics Amazon.com: Scosche EBT Battery Terminal with ABS Cover: Car Electronics
To battery change on 2012 base model
Quick Reply: battery change on 2012 base model
