Base C6
Old May 25, 2016 | 07:35 PM
Jp23rockstar's Avatar
Jp23rockstar
Default Base C6
Are there any aftermarket solutions to get the C6 to have a tighter suspension and handle better?
Old May 25, 2016 | 07:39 PM
LifeInAVette's Avatar
LifeInAVette
No expert in the category, but I'd think aftermarket sways and shocks (Bilstein Sports?) would be a good start.
You may have to define "handle better" a little more specifically.
Old May 25, 2016 | 07:45 PM
Kent1999's Avatar
Kent1999
Upgrade to OEM Z51 sway bars, if your car isn't already equipped. Makes a MARKED difference over base suspension and its cheap!
Old May 25, 2016 | 07:53 PM
Welker1's Avatar
Welker1
After test driving a few with & without the Z51 package, I ordered mine with it. IMO the handling is night & day ... mine handles extremely well through the mountain passes
Old May 25, 2016 | 08:17 PM
Jp23rockstar
I guess feel more planted to the ground.
Old May 25, 2016 | 09:12 PM
rkj427's Avatar
rkj427
Pro Mechanic
Check out Cultrag Performance, a forum vendor, for sway bars and shocks, they make a big difference compared to stock.
Old May 25, 2016 | 09:44 PM
Boomer111's Avatar
Boomer111
I solved this problem with the addition of Z51 sways and Koni FSD shocks along with non RF tires and a thicker tunnel plate.
To my experience it rides better than the Z51 due to the the softer springs rates.
Old May 26, 2016 | 02:33 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you for the referral. I certainly appreciate it.
Old May 26, 2016 | 04:10 PM
cclive's Avatar
cclive
I did the Z51 bars and Bilstein shocks...night and day for $500 total.
Old May 26, 2016 | 04:19 PM
Mike's LS3's Avatar
Mike's LS3
Did the same thing and ordered the Z51 option. I laugh when some people say "I didn't feel much of a difference between the two". It's night and day! Since then, I have added Bilstein Sport shocks, Michelin Super Sport tires 265/305 and wider TSW rims, the difference is even greater.
Old May 26, 2016 | 04:21 PM
TerryL's Avatar
TerryL
St. Jude Donor '17
Bilstein SPs did it for mine. Stays planted perfectly in the twisties, on bad roads and good roads. Very satisfied with them.
Old May 27, 2016 | 03:07 PM
Allen_B's Avatar
Allen_B
Everything I've read and heard also points to Cultrag and plan to go with one of their packages when I upgrade.
No personal experience but have heard nothing but praise so take it for what it's worth...
To Base C6
