Need some more ideas on bodykits for c6 base model coupe. Any and all pics appreciated. Looking online and theres only a select few to choose from. Need more ideas. Thanks
Keep the C6 base as it is. It's the most cost-effective route, and the C6 lines are sexy enough.
If you're hell-bent on changing the look (to something like a GS or Z06 widebody), then 1) sell your base and 2) buy a GS or Z06. It's the cheapest route by far.
Title still says C6 base when you go to sell. No 427 under the hood either.
Some of us like the Coupe but want the bigger rear tires. Before I did mine the rear end would get squirrelly upon sudden full throttle, now it stays straight and hooks up very well.
OP...RPI makes one that comes pre painted and several forum members have been happy with them. I believe they are the least expensive route. You can expect to spend $5-$7 grand after new wheels and tires ( if you do the install yourself).
(The ZO6 and ZR1 are FANTASTIC. If you decide to sell the coupe that's what I recommend).
Good luck with your project. When it's completed you will be proud of the accomplishment.
