A New TSB
Old May 28, 2016 | 12:36 PM
WA 2 FST's Avatar
WA 2 FST
Originally Posted by pewter99
unplug it...spray some contact cleaner in it...plug it back in and zip tie it.....
Exactly... no way I'm taking it to the dealer for this... only to have them scuff up something on the car while they fix it.
Old May 28, 2016 | 01:52 PM
Dcasole's Avatar
Dcasole
while kneeling outside the car move your seat up and all the way forward you will see the yellow plug, it may or may not be attached to the seat rail....pull it down unplug, spray some contact cleaner in there and plug it back in....wrap zip tie around the plug between the wires...pull TIGHT.....done
That's exactly the fix .. just watch you don't pull it down on top of the wires , there is just enought room to just cinch it down on the connector
I will send my address for my free zip tie lol lol
Old May 28, 2016 | 01:53 PM
Dcasole's Avatar
Dcasole
Originally Posted by Not So Fast
AND THE HARMONIC BALANCER, I am dreading that one if it pops up.
NSF
NSF, are u still under warranty ??
Dave
Old May 28, 2016 | 04:46 PM
Not So Fast's Avatar
Not So Fast
Dave
Nope Dave, time lapse, not mileage
Got my notice today and wished it had been for the HB
Not chirping yet though but does have a wobble
NSF
Old May 28, 2016 | 07:43 PM
tealex's Avatar
tealex
I have avoided the problem (unknowingly) buy simply putting the seat where I wanted it the day I bought the car and not letting anyone else drive it. Working fine since Jan. 2013 !!!
Old May 28, 2016 | 09:38 PM
enventr's Avatar
enventr
Default A Letter from GM
Why wasn't this a recall ? Why some were affected and some were not?
Old May 28, 2016 | 09:42 PM
schizcat's Avatar
schizcat
Heh. I got one too. The letter tells me that my 2005 Corvette can be repaired if its not more than 10 years old or has 120000 miles....whichever comes first. Thanks GM. The issue started 2 years ago before the 10 years, but we are just now getting the letter. Steller customer service.
Old May 28, 2016 | 09:44 PM
ROJ#79's Avatar
ROJ#79
I got one too for my '08. I never move the seat so I should be good to go!
TerryL's Avatar
TerryL
St. Jude Donor '17
Got the same letter and had a good laugh too. Mine's an 06! So, in their infinite stinginess and lack of responsibility, GM decides to warn me of a defect IN THE TENTH YEAR OF ITS OWNERSHIP which also coincides with the time limit expiration for GM to fix it under warranty...way to go GM! It's great knowing you're looking out for me.
Old May 28, 2016 | 09:45 PM
USA1 427's Avatar
USA1 427
Mine says 2013. Got it two days ago.
Old May 28, 2016 | 09:52 PM
enventr's Avatar
enventr
If I didn't love this car I would be getting another Lexus. They hardly have any issues. GM needs to definitely step up especially on their flagship models.
Old May 28, 2016 | 09:54 PM
enventr's Avatar
enventr
Why only some were affected ? Same design and same connector. They should all be brought in for inspection
Old May 28, 2016 | 09:57 PM
  #33
J3TVETTE's Avatar
J3TVETTE
Really? My friend's IS250 was junk. The door panels started coming off in chunks. She went to the dealer and Lexus refused to cover it. The dealership said they get 2-3 IS250's a week with the same issues. Literally melted and coming off in chunks.
Old May 28, 2016 | 10:02 PM
  #34
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Believe it or not, GM is a "for profit" company (yes, I know about the banko) and likes to reward it's stock holders with profits.
Having said that, I was the sole driver of my '05 as I am with my '11. My suspicion is the movement of the seat is what makes the connector come apart. GM's thinking is why repair them all when only some will fail. If it fails in a (GM) reasonable amount of time they will fix it.
OK, I have my iron pants on so flame away...
Old May 28, 2016 | 10:20 PM
  #35
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default Did-it-myself
I fixed my own when I installed the seat firm-it-up package. According to the GM letter I too received, they owe me for the 2 zip-ties I used to hold the connector tightly together and position it out of the way. If only I had kept the receipt for those two zip-ties . . . . . .
By the way, my use of the zip-ties, a couple of years ago, COMPLETELY solved the recurring issue I was having .
  #36
jsucraig's Avatar
jsucraig
My problem wasn't the connector, rather the wires and their pins going into the connector. The wires kept breaking off at the pins crimp. The first I had fixed at the dealer where they merely cut the mate to the wire that had broken form the pin, twisted the wires together, and wrapped the connection in electrical tape. While they were there I later found out that they had cut the insulation on an adjacent wire in the loom and it had started to short against the rod on the bottom of the seat that holds the connector. I found this out when my airbag light started to come on again. To fix the issues I removed the original Airbag Connector and used removable connectors on all of the wires connect to their mates and affixed them to the seat rod with Zip-Ties. No more Airbag Light.
FWIW: I am an Aircraft Mechanic, all tools and parts used were certified for use on aircraft electrical systems.
Old May 28, 2016 | 10:23 PM
  #37
enventr's Avatar
enventr
I have a higher end model but I don't know if that has anything to do with it. This is my second Lexus and my friends second Lexus and no problems.
To A New TSB
Old May 28, 2016 | 10:38 PM
  #38
Proff's Avatar
Proff
Got same letter for my 2009.
I guess they sent letters to all C6 owners in the database.
Yeah, the same 'two-zip-ties fix' worked for me.
Paul
Dallas
  #39
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
I got it too. It's filed with the letter about the fuse box wire and that's where it's going to stay. ( Hopefully )
Old May 28, 2016 | 10:40 PM
  #40
ttx350z's Avatar
ttx350z
My car started getting the airbag light 2 weeks ago. Got the letter a week ago. Dropped it off yesterday morning at the dealer and had it done in about 2 hours. No fuss and no drama.
There was another vette there as well, not sure if it was there for the same issue or what.
