Laps at Talledega, now engine issues
Old May 29, 2016 | 10:58 AM
hydrasport's Avatar
hydrasport
Default Laps at Talledega, now engine issues
Ran Vetts4vets Saturday at Talladega. Second run was more fun as speeds were a little higher. Skipped third session and headed home early because the engine had some "misfires" at higher speeds. ('08 ls3) No DTC's, just did not run right. Got about 150 miles down the road and stopped at a rest area. Engine stumbled bad and died. Noticed it running worse and worse at idle and stumbling at highway speeds as trip home progressed. DTC light came on and it began random hard misses. Eventually lost power and went into reduced power mode. luckily made it to an exit where it died and would not restart. Trailered it home the last 150 miles. Got home at 2 A.M.
Plugged the diablo into it to run trouble codes. The battery is still good but the code reader will not read anything. It just keeps saying turn the ignition on. The ignition is in the acs mode. No starter engagement at all now when I try that. It had one long crank - no start attempt last night so I'm thinking that may have locked out any more restart attempts. Any suggestions on how to get trouble codes without a code reader? First place that I want to look is connections at the PCM but without codes I'm just looking around for obvious damage to sensors or wiring. I don't think that will fix anything.
Old May 29, 2016 | 11:24 AM
User Omega's Avatar
User Omega
If you don't have a reader there are many auto parts locations that offer the use of one without having to purchase it. Id ask to see if you could borrow it and take it home. You may as a last resort pick one up from a local store and return it if you don't want it. Good Luck!
Old May 29, 2016 | 11:28 AM
Bruze's Avatar
Bruze
Sometimes it helps to actually read a post before replying to it.
Old May 29, 2016 | 12:20 PM
hydrasport's Avatar
hydrasport
I appreciate all responses. I have a diablo tuner. I was able to get the scanner to read codes a few minutes ago. The engine actually cranked after we unloaded the car. It's in my shop now. The diablo tuner stated
"1 code". It will not show the code. I do not want to clear it yet. Going straight to fuel pressure and pcm connections. Any other suggestions where to start. Again I have one code but cannot see what it is.
Old May 29, 2016 | 12:50 PM
truckplay's Avatar
truckplay
carefully and without burning your hands make sure none of the plug wires have come loose from the coils. The heat and vibrations can cause them to come loose.
Old May 29, 2016 | 01:14 PM
BlindSpot's Avatar
BlindSpot
I don't think Diablo will read in accessory mode. Put it in run mode just like you're loading a tune. Also, Diablo only reads P codes. It won't read GM specific codes. So, if you show one but it won't read it you need a different scan tool that will read GM codes. Autoenginuity will with the GM addendum and is probably the least expesnive before you get into real factory tools. Not likely a fuel pressure prob as that will set a P code....unless your Diablo is gnarly.
Old May 29, 2016 | 01:21 PM
hydrasport's Avatar
hydrasport
More information. The fuel pressure is 62 psi. Oil pressure normal.
One of the issues that I'm looking for is the erratic control of the starter. Engine will spin sometimes and stop when I release the button. Then sometimes it will try to recrank the engine on it's own if the engine does not start on the first attempt. In other words, spin the engine, no start and the starter disengages on it's own then without hitting the button again it tries to restart the engine. Almost like a short in the wiring. But the starter issue, I think, is only happening because of another issue. If the engine does start, it runs OK for a few seconds then dies or quickly seems to loose ignition of fuel. Just like last night on the interstate, engine shuts down but quickly reengages. But the reduced engine power shows other issues also.
Does the BCM control the starter and ignition circuits?
Old May 29, 2016 | 01:28 PM
unixcorn's Avatar
unixcorn
I think you nailed it with your electrical short diagnosis. You made a couple of high speed runs. If your exhaust got super hot during the runs, could it have melted wires around the starter or in another area? I will be curious to hear what you do find. Good luck!
Old May 29, 2016 | 02:45 PM
hydrasport's Avatar
hydrasport
Why would the code reader show that I have one trouble code and not be able to show what it is and it cannot clear the code? It may be a hard code so it cannot clear it, but what code would not be available for the code reader?
Old May 29, 2016 | 03:10 PM
cclive's Avatar
cclive
This is the first and easiest thing to check...before even getting the code scanner out.
Old May 29, 2016 | 03:23 PM
hydrasport's Avatar
hydrasport
Checked those easy to see things last night while waiting for a trailer. Starter wires are fine. PCM and BCM wiring is good and clean. Sometimes it starts and sometimes it just spins and sometimes it does nothing.
Old May 29, 2016 | 03:28 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
No cracked/broken bakelight on the starter solenoid?
Old May 29, 2016 | 04:03 PM
biker1059's Avatar
biker1059
Here's a thought, disconnect your battery and let the computer reset. Maybe it will throw some codes after that. Anything is worth a try when your car is acting up.
Old May 29, 2016 | 05:35 PM
hydrasport's Avatar
hydrasport
Thinking the PCM has an issue. Intermittent problems and a wide range of problems. It's not the starter or connections, those wires are only for the starter power feed. Gona look inside the fuse box and after that, PCM. Should be able to buy a new PCM for about $300. Should be able to buy a new PCM and not have to program it. Am I correct on that?
Old May 29, 2016 | 06:36 PM
C6 Snowboarder's Avatar
C6 Snowboarder
not to be picky here but do you mean an OPEN in the wiring or an actual SHORT of a wire to ground/or another wire circuit?
Old May 29, 2016 | 07:05 PM
Dcasole's Avatar
Dcasole
I am putting my money on a bad ECM unit ...
Dave
Old May 29, 2016 | 09:19 PM
hydrasport's Avatar
hydrasport
Yes, an open circuit, or bad connections in all the associated connectors. But also looking for any chaffing of wires. Covered most of that today. Can't do much else right now.
Does the starter circuit go through the ECM? It works erratically.
Can't remove the diablo tune that is installed. No communication from the car to the tuner right now, but that is random. It might work the next time I go out to the shop. The starter function does not work now and when in the acc mode, the fuel gauge does not read. It cranked a few times earlier today.
To Laps at Talledega, now engine issues
Old May 29, 2016 | 10:00 PM
cclive's Avatar
cclive
None of the gauges on mine work in ACC mode.
Old May 29, 2016 | 10:33 PM
hydrasport's Avatar
hydrasport
Just successfully removed the diablo tune and reinstalled the factory. Tomorrow I start looking for a new ECM/PCM. Diablo tune was removed in the acc mode. The start circuit is dead. When it does start, it runs bad for a few seconds and dies. Only one code and I still don't know what it is. Who agrees ECM?
Old May 29, 2016 | 10:43 PM
HOXXOH's Avatar
HOXXOH
You have to hold the ACC button down for about 5 seconds to get into run mode and the gauges to function. Do a good test on the battery to make sure it's fully charged. Check the main cable connection at the solenoid to make sure it doesn't wiggle, since a visual is not enough to tell if the case is cracked.
Although rare, you might check plugs to see if the iridium tips are still there and could be the initial cause of misfires.
Once you run out of self-diagnose choices, pay someone to check codes with a tech II or equivalent before spending anything for the parts swapping routine.
