Problems starting
Old May 29, 2016 | 07:38 PM
Twesley's Avatar
Twesley
Cruising
Default Problems starting
Need help my 08 corvette will not start all but all my accessories work could someone please help had a phone charger in the center console took it out and the car started up drove to the gas station got home and she wouldn't start any suggestions???
Old May 29, 2016 | 07:43 PM
Welker1's Avatar
Welker1
Based on the info you provided, my first guess would be a bad battery, second would be a bad alternator. You can have both checked at your local parts store ... good luck
Old May 29, 2016 | 07:51 PM
4SUMERZ's Avatar
4SUMERZ
Check the connections at the battery and at the starter as well. If all those are tight, and nothing that looks out of place, then get your battery load tested.
If your alternator is putting out 14 volts, then it should be ok, but you can also have that checked.
Good Luck
Old May 29, 2016 | 07:53 PM
the kid C6's Avatar
the kid C6
The owner's manual says that phone chargers will interfere with your car's electronics.
Old May 29, 2016 | 07:58 PM
owc6's Avatar
owc6
Bingo! Although, all the above issues could make this worse .
Old May 29, 2016 | 08:01 PM
Not So Fast's Avatar
Not So Fast
Been there, done that Crazy eh
NSF
Old May 29, 2016 | 10:18 PM
cclive's Avatar
cclive
You need to be more clear..."wouldn't start"...does that mean it turns over endlessly but never catches or it doesn't turn over at all? Does the DIC give you a message when this happens?
Old May 29, 2016 | 10:40 PM
Twesley's Avatar
Twesley
Cruising
It doesn't catch at all...but the DIC just gave me the message service the charging system
Old May 30, 2016 | 07:49 PM
Twesley's Avatar
Twesley
Cruising
Ok got a new battery but car still not starting. ..so Im thinking either a fuse or bad starter what do you guys think????
Old May 30, 2016 | 10:13 PM
Shannon Arceneaux's Avatar
Shannon Arceneaux
sarceneaux
its not battery, I have a video of what it does, but my video is bigger than what the forum will upload and I need all of video to show what it is doing.
any other way I could send you the video
shannon
Old May 30, 2016 | 10:25 PM
Twesley's Avatar
Twesley
Cruising
shannon
I sent my email check your inbox
Old May 30, 2016 | 10:26 PM
Twesley's Avatar
Twesley
Cruising
shannon
Check your inbox
Old Jun 1, 2016 | 12:46 PM
Twesley's Avatar
Twesley
Cruising
Thanks to everyone who replied it was my starter and neg cable post now shes ready to RIDE!!
To Problems starting
