Traction Control
Old Jun 1, 2016 | 04:35 PM
703's Avatar
703
Default Traction Control
Wanted to do some spirited driving yesterday and noticed that my traction control button doesn't work?
Some of my initial thoughts are, car has an aftermarket stereo. Previous owner didn't 're connect it. And one of the tpms isn't hooked up so maybe that's an issue?
Any input is welcome.
Thank you.
Old Jun 1, 2016 | 04:40 PM
Vette_DD's Avatar
Vette_DD
A little information that may or may not help you.
The system has four modes.
Mode 1 is the default when you turn the car on. Full traction control and full active handling.
Mode 2 is one press of the button which is traction control off Active Handling on.
Mode 3 is two presses in five seconds. This is traction control off and active handling in competitive driving mode which will give you greater tolerances for sliding sideways (what you want on a road course)
Mode 4 is to press and hold for greater than five seconds. This will be traction control and active handling off. No intervention from either system.
Traction control is just that. It senses rear wheel spin (loss of traction) and will take appropriate action to reduce said wheel spin. It will pull timing to limit wheel spin. It monitors the ABS sensors and the wheel speed sensors along with RPM.
Active handling takes input from several sensors in the vehicle. It pays attention to wheel spin, rpm, throttle input, brake input and yaw (departure angle of the nose of the vehicle from straight.) The car will take what it believes to be appropriate actions including applying individual brakes and reducing throttle input. The F55 in addition will vary individual shock damping to allow the car to plant an individual wheel to regain better control if it senses the car being loaded in a given direction.
Old Jun 1, 2016 | 06:40 PM
dr_gallup's Avatar
dr_gallup
If only one TPMS does not work the sensor probably has a dead battery. Should not affect TC/AH.
Old Jun 1, 2016 | 09:52 PM
703's Avatar
703
When I press the button nothing comes up on the dash. The one tpms isn't hooked up (sitting in my trunk)
Old Jun 1, 2016 | 10:46 PM
LMB-Z's Avatar
LMB-Z
remove the console and see if it is connected.
Old Jun 1, 2016 | 11:07 PM
ray_ray's Avatar
ray_ray
I believe if a tire sensor is out it will not let you change or take off your traction control for safety reasons.
Old Jun 1, 2016 | 11:35 PM
SlowBusa08's Avatar
SlowBusa08
if the removed tpms sensor is still alive simply lay it next to the wheel(assuming it's still paired with the bcm) It will pick it up. try turning your tc/ac off then.
Old Aug 12, 2019 | 10:24 AM
ThisisLivin's Avatar
ThisisLivin
Very Interesting, I have been trying to get my traction control off and I have a bad TPMS sensor.
Old Aug 12, 2019 | 01:07 PM
Seno's Avatar
Seno
C6 of Year Finalist (stock) 2019
I have a couple of TPMS that have dead batteries and I cannot get into Competitive Driving Mode. However, I am able to turn traction control on and off.
Old Aug 12, 2019 | 05:31 PM
CHEV AGAIN's Avatar
CHEV AGAIN
NO it won't.....🤨
Old Aug 12, 2019 | 05:44 PM
ThisisLivin
Thanks for the tip. I had the bad TPMS replaced and everything works as advertised. That's been driving me crazy, problem solved.
To Traction Control
