Seat Cover - Mid section only
Old Jun 7, 2016 | 10:48 PM
Corvette505's Avatar
Corvette505
Default Seat Cover - Mid section only
Anyone seen a cover or replacement for the middle part of the seat (the part that your middle and lower back rests against) on a basic C6? I don't want new seat covers by any means, just wondering if i could switch out that middle part for a different color or cover it, for a unique look.
Old Jun 7, 2016 | 11:41 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
You can order the seat back middle section in several colors from Gene Culley of Cultrag (a forum vendor).
It is possible to swap out just the back middle piece with the seats still in the car.
I'll post some photos tomorrow.
Old Jun 8, 2016 | 02:34 PM
ncvette_1FUNRIDE
Here is what the seat looks like behind the back center section. There are 2 plastic clips that catch metal brackets on the back of the seat insert.
You would have pull out the top portion of the seat center insert as you pull up to slip the metal brackets out of the plastic clips.
NOTE: This would be AFTER you take out the 2 black plastic retainers that hold a FLAP to the back of the seat frame.
Old Jun 8, 2016 | 02:54 PM
Joe B.'s Avatar
Joe B.
If it's mostly for sweat containment, get a towel in the color you like, trim it and stuff it in the gap.
Old Jun 9, 2016 | 01:28 PM
Corvette505
Thanks a ton NCVette, really appreciate the advice and how-to, you Rock!
Old Jun 10, 2016 | 06:36 PM
Corvette505
Now if only i could find it in white LOL
Old Jun 10, 2016 | 07:18 PM
ncvette_1FUNRIDE
The only way to do that is to take your center section out and take it to a local auto upholstery shop and have them make one for you using your current center section as a pattern.
There is no OEM white, but there is a 4LT color called LINEN that is an 'off white' color.
Old Jun 18, 2016 | 02:39 PM
Corvette505
Thanks,I'll have to look into that!
To Seat Cover - Mid section only
