Reprogramming FOBS
Old Jun 15, 2016 | 05:50 PM
1restoman1's Avatar
1restoman1
Veteran: Coast Guard
2023 C1 of the Year Finalist - Modified
Default Reprogramming FOBS
When using the Sticky "No Fob detected" can anyone tell me
1. Did you leave the car doors open or closed when doing the long procedure ( no working fobs and are programming a new set)
2. The last step says" Failure to press the UNLOCK button of each key fob will result in that fob being inoperative" . Do you do this step after all the remotes have been programmed, or after each one is finished. I will be doing 3 fobs
Old Jun 15, 2016 | 06:15 PM
pagosawingnut's Avatar
pagosawingnut
Veteran: Marine Corps
St. Jude Donor '17
I believe it is after each fob is done.
Old Jun 15, 2016 | 08:16 PM
billyjoeraybob's Avatar
billyjoeraybob
Yes after each fob is done. I did this recently when I replaced fob1
To Reprogramming FOBS
