Help with brakes please!!
Used pads and used rotors i gather? Naturally one cannot expect them to bed in perfectly as neither are straight and with some taper. I am actually surprised that the fronts bedded perfectly. That is more unusual. This is very normal. Did you do break in? Just let it go, with more usage they will get evened out. I really would not loose any sleep over that at all.
I'm wondering if I could just leave them and they'll wear themselves flat. It's either that or replace. Idk. I'm on a time crunch otherwise I'd say just to replace.
Supporting Vendor
St. Jude Donor '11,'13
Here is my take. First off once a carbotech pad is bedded it does not need to be bedded again. So, what you were doing is actually using up pad material. I would check the rears and make sure everything is lubed and siding freely in the caliper with that being said if all is good I would not hesitate to use them. What bedding process did you use? If the xp8 compound is smooth and very shinny you glazed them . If glazed than I would chuck them. What's your time frame?
My timeframe is until Thursday. My first HPDE is Thursday AM.
Supporting Vendor
Yes, you should lay a transfer layer down on new rotors. But the xp8 would have done that with out bedding them since they where bedded before. What is your bite like now?
And no that is not the purpose of bedding pads Carbotech pads need to be bed to release the gasses in the binding material of the friction compound. This is why I always recommend pre bed XP series so, you can take a few laps easy and lay the material down and go no need to bed. You should actually bed new rotors with old pads so that layer is down there before this is assuming you are using the same brake pad manufacture.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Using used brake parts on a old DD or beater is one thing, but heres a good rule of thumb for a high performance car such as our Corvettes. Used rotors.....never. Used pads....never.......
Yeah apparently that's a no no. New rotors, pads with barely any use. Figured no problem. It was given to me by a good friend who has a lot of experience on the track with more than a few cars. Figured it would be fine. You live and learn though. The question is now to leave it or replace.
It's not like it's some beater from the northeast where salt & corrosion have left rust or high spots on the caliper mounting surface that would cause the pad to sit wrong. Still worth checking that those surfaces are clean & flat without any debris. Checking that is just a standard part of ANY brake job though.
Just like not using a big C-Clamp or pad spreader and just pushing the pistons back, thus forcing all the sediment & crap back into your nice expensive ABS unit. (open bleeders & drain fluid into container while pushing pistons back to help prevent this.) Or cleaning hub flange surfaces to make sure the rotor sits true, or checking the rotor run-out to make sure it is in spec...etc.
I was originally adviced that it would even out with some heat and use. So forgive me for asking the question, I'm on a time crunch now so I wanted to at least ask and double check.
