My Custom LED Tail Lights
Everyone seems to have the eagle eye LED tails, so I wanted to do something different. Bought some 2 wire LED rings, some load resistors and diodes and went to work. Baked the lights in the oven, separated the lenses, inserted the rings, sealed them up, and wired them up to be functional running, brake and directionals with no rapid flash (load resistors). LOVE them. Not bad for about $100 worth of materials. The only issue i need to sort out still appears to be some static on the radio when the brakes are applied, which seems to be a common issue with LED tail lights.
Received 1,675 Likes
Nice job!
Those are very cool!
They look good.
Can you give us a parts list? Impressive work.
Man, those look great. Much better than Eagle Eyes ... you really need to post the parts list and some photos of the process .... !
Very cool DIY.
To block the RF interference coming from the lamps you can try a couple things.
Shield the backside of the lights with tin foil/copper screen/stainless steel screen/etc. that is tied to ground.
You can also try putting RF Chokes on the 12V wires as close to the lights as you can.
Remember the AM/FM antennas are mounted on the rear wall of the trunk so they are very susceptible to picking up any RF 'noise' coming from the lights.
https://en.wikipedia.org/wiki/Choke_(electronics)
This is a simple ferrite clamp inductor that is cheap and easy to install.
This is the ground point on the rear bumper.
Very cool DIY.
[IMG]https://cimg4.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/1449x1449/80-
img_20160622_205304_d204041bc66f1f30c096 55f65b75271d78512ec1.jpg[/IMG]
