Ground Clearance
Old Jul 1, 2016 | 05:41 PM
bnkvette's Avatar
bnkvette
Veteran: Marine Corps
Default Ground Clearance
Is there any way to increase the ground clearance on my C6?
Thanks Brit
Old Jul 1, 2016 | 06:22 PM
bnkvette's Avatar
bnkvette
Funny
Old Jul 1, 2016 | 06:37 PM
Johnathon59's Avatar
Johnathon59
I went with adjusting the lowering bolts & larger size tires, it helped some, about 1 1/2 " more clearance not much but I don't scrape anymore in driveway
Old Jul 1, 2016 | 06:39 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
What is the condition of the springs and shocks? What is the height from the ground to the lip of the fender well measured at the center of the wheel?
You may be able to raise it using the spring bolts if it has been lowered.
Old Jul 1, 2016 | 06:42 PM
tealex's Avatar
tealex
I raised mine with the raise/lowering bolts. I got 1/2 to 5/8 inch in the front and that's all I needed. Also had an alignment done afterwards.
Old Jul 1, 2016 | 08:08 PM
Red Devil's Avatar
Red Devil
Is the car a base C6? Does it scrape on all inclines or just steep ones? If it's just the air dam and does it once in awhile I wouldn't worry about it. I actually removed mine from my GS as it's lowered with no ill affects.
Old Jul 1, 2016 | 08:24 PM
bnkvette's Avatar
bnkvette
I have a steep driveway and it scrapes when backing up into the garage. Also, it seems like it scrapes on even the slightest incline.
Old Jul 1, 2016 | 08:26 PM
bnkvette's Avatar
bnkvette
By changing the ground clearance effect the handling? I have a base C6 convertible.
Old Jul 1, 2016 | 08:31 PM
CadVette's Avatar
CadVette
Short of putting an expensive air suspension on it there is not much you can do. If you do then you will have to deal with an air compressor and tank in the back. Not sure if your roof will fit in afterwards if your car is a coupe. I'm not going to put the air dam back on mine, it's half torn up now anyway.
Old Jul 1, 2016 | 09:24 PM
Red Devil's Avatar
Red Devil
How many miles on the shocks? Have you measured all 4 corners of the car to see what height you are at?
Old Jul 2, 2016 | 02:10 AM
RED84CF's Avatar
RED84CF
You think your base scrapes, wait till you see how much a GS scrapes, I love how low it looks and I'm not changing it just be a little careful how you approach curbs and dips in the road.
Old Jul 2, 2016 | 03:10 PM
bnkvette's Avatar
bnkvette
I think the shocks were replaced in 2008. I'll have to measure the corners. Thanks
Old Jul 2, 2016 | 03:13 PM
bnkvette's Avatar
bnkvette
Thanks for the info. I'll have to save my money and get a C1 or C2.
Old Jul 3, 2016 | 12:23 PM
icntdrv55's Avatar
icntdrv55
Do new/replacement shocks significantly affect the ride height of the car? Always thought that was a function of springs...
Old Jul 3, 2016 | 06:28 PM
Boomer111's Avatar
Boomer111
One would think this.
When I installed the koni FSD shocks my car lowered around 1/4 inch.
I knew to expect this so I measured before.
Sometimes real life experiences have their own science.
Old Jul 3, 2016 | 07:39 PM
Cherokee Nation's Avatar
Cherokee Nation
Remove the air dams, they do NOTHIN for cooling. I removed my 3 years ago.
Old Jul 4, 2016 | 10:04 AM
_05C6_'s Avatar
_05C6_
As others have said, if the scraping you're hearing is the air dam pieces there is nothing to worry about.
In actual literature printed when the C6 first came out, the front air dam pieces are there for just that purpose, as audible acknowledgment that you're getting close to something.
I removed the two outer pieces on mine.
To Ground Clearance
