please help code P2138
Old Jul 4, 2016 | 08:28 PM
mancobra's Avatar
mancobra
Default please help code P2138
I have 3 codes P1516 / P2101 / P2138 ( reduced engine power )
my car is stock 2009 base model , what can I do to fix this ?
please help thanks
Old Jul 4, 2016 | 08:42 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
This site may help you with the codes and possible resolutions.
Vehicle Codes
Old Jul 4, 2016 | 09:36 PM
RicK T's Avatar
RicK T
The P2138 is one of the 2 common Accelerator Pedal Position sensor codes that "usually" means you'll need a new accelerator pedal assembly....BUT first....
Check post 2 in this thread for TSB info on a possible connector issue with that code:
https://www.corvetteforum.com/forums...ectorx184.html
Old Jul 4, 2016 | 11:43 PM
extrapilot's Avatar
extrapilot
please help thanks
A few easy things to check;
Check for a broken wire that is located at the throttle body connection. Give a tug on each individual wire at that connector, as there has been issues with broken wires inside the insulation. Check for dirty pins inside the connection there as well. A dirty throttle body can create these problems.
Old Jul 5, 2016 | 07:34 PM
mancobra's Avatar
mancobra
thank u , I did all those and nothing I don't know what else to check
Old Jul 5, 2016 | 09:23 PM
extrapilot's Avatar
extrapilot
Did you check the thread that rick t pointed to?
Does the throttle body look dirty/stained, as it would not hurt to clean with the correct cleaner.
Other than that, dealers/mechanics have the Tech 2 to perform more in depth testing of the code P2138, Accel Pedal Pos (APP) Sensor 1-2 Correlation.
If you are real good at understanding the circuits and have access to a vom, there are tests that one can perform on the APP.
Alternately, after reviewing some of the issues listed here, you could take a chance at replacing the accelerator pedal.
The P1516 points to the throttle body or the tps's that are built inside the unit.
These issues drive even knowledgeable people crazy.
Old Jul 5, 2016 | 09:36 PM
extrapilot's Avatar
extrapilot
I see that you have the Vitesse controller. Did you try removing the unit and resetting the trouble codes?
Old Jul 6, 2016 | 12:26 PM
_05C6_'s Avatar
_05C6_
^^^^ what he said. Your vehicle is not 'stock' if you have the Vitesse controller added.
Remove that from the equation and see if the problem corrects itself.
Keep us posted.
Old Jul 6, 2016 | 01:47 PM
cclive's Avatar
cclive
Keep us posted.
Gotta get that out of the picture to rule it out as a cause of the issue.
Old Jul 6, 2016 | 08:09 PM
mancobra's Avatar
mancobra
Keep us posted.
I took out the controller and ...well for 30 min everything okay and then.... came back
( reduced engine power ) I just order a pedal , I hope the trouble is that if not I don't know what else
Old Jul 6, 2016 | 09:10 PM
VitesseMotorsports's Avatar
VitesseMotorsports
Banned Scam/Spammer
Error code P2138 is very common on many GM Cars including their Trucks.
It's your TPS ( Throttle Position Sensor ) going bad.
Will need to replace your Gas pedal
Old Jul 7, 2016 | 09:17 PM
mancobra's Avatar
mancobra
well I just put in a new pedal , re-programed my vitesse throttle controller I went for a ride and so far everything A1
lets hope for the best
thanks everybody for the help
Old Jul 8, 2016 | 03:15 PM
Roadrogue's Avatar
Roadrogue
I am having the same problem with my C7 and was wondering if it was related to the Vitesse. Please post if replacing the pedal assembly did the trick. Mine works fine for hours and then malfunctions so its hard to know what works.
I'm still under warranty so I guess the dealer will fix it but I suppose I better remove the Vitesse before taking it in. Was the throttle pedal expensive?
Old Jul 8, 2016 | 10:22 PM
mancobra's Avatar
mancobra
yes so far second day and no more problems ,i put back the Vitesse controller , price for the pedal in Canada $150 cdn at the dealer
im happy again
take out the controller and if it still does it , them its the pedal
Old Jul 9, 2016 | 02:24 PM
Roadrogue's Avatar
Roadrogue
I pulled the Vitesse and I am out on a drive. About 60 miles and good so far. But it went further than this previously and then failed so we'll see.
Old Jul 20, 2016 | 08:54 PM
mancobra's Avatar
mancobra
well bad news on my side , it went okay for a few days and today code 1516 and 2101 came back I don't know what to do , I took out the vitesse controller I went for a ride and so far okay , maybe my vitesse controller is fu...g everything up I don't know
is there a reset I can do ? or what should I do ? thanks
Old Jul 20, 2016 | 10:36 PM
Dcasole's Avatar
Dcasole
Guy's take the Vitesse out and leave it out until you are sure that you have corrected the problem .
And then if you reinstall the Vitesse make sure you recalibrate it
Every post about a Vitesse throwing codes always is cured with a recalibration ......
Dave
To please help code P2138
Old Jul 21, 2016 | 08:23 AM
Roadrogue's Avatar
Roadrogue
Default Recalibrate
Good advice. I talked to Ahmed at Vitesse and he said the same thing. He also said to move the black box somewhere cooler than where I had it behind the carpet. I did both yesterday and so far so good.
Old Jul 21, 2016 | 11:10 AM
Dcasole's Avatar
Dcasole
Ahmed is very responsive , good news to hear !
Old Jul 21, 2016 | 09:04 PM
mancobra's Avatar
mancobra
Dave
well I took the Vitesse out , it was okay for a few milles and then came back code 1516 and 2101
should I change my throttle body ?
