Love the ceramic. More expensive, but if you do park out in the hot sun frequently, the heat reduction with ceramic is better than the others. I also put clear ceramic on the windshield. Full ceramic will keep the car up to 10 degrees cooler than standard tint.
Mingo from Suncap AutoTint has a very effective selling tool that clearly displays the real world difference between window tint types regarding blocking infrared heat.
He has a infrared light bulb encased in a 4-sided glass box that spins. Each side of the case is tinted with a different tint type: 50% ceramic, 35% metallic, 5% metallic and no tint at all. By spinning the sides you can feel the amount of heat that transfer through the tinted glass from the infrared bulb. The 50% ceramic is practically clear compared to the other tint shades but blocks the most heat, even over the 5% limo tint.
