TPMS Life Span
Old Jul 9, 2016 | 08:52 AM
mracer's Avatar
mracer
Quick question.......... If a sensor registers no pressure (battery dies), does this cause the ECM to put you in limp home mode (50 mph)?
Mike ;>)
Old Jul 9, 2016 | 09:30 AM
owc6's Avatar
owc6
Mike ;>)
There is no limp mode due to tire pressure, just a message on the DIC. You can even clear it, for that ignition cycle, by pressing reset
Old Jul 9, 2016 | 10:05 AM
Welker1's Avatar
Welker1
Know this to be true from personal experience. Didn't haft a dead battery, had a flat with zero pressure & didn't go into limp mode
Old Jul 9, 2016 | 10:33 AM
windyC6's Avatar
windyC6
Originally Posted by CadVette
I've seen them for sale on EBay for reasonable prices. Shopping around helps as I've seen the prices vary widely. It's also possible to refurbish the old ones if you're handy digging out the battery and soldering a new one back in its place, then silicone it back in there.
Wouldn't recommend this route. I took my old one apart just to have a look inside and see how much trouble swapping the batteries out may be. ROYAL PITA !!! Digging all that goop out of the way without damaging everything just isn't worth the hassle. And then you have to solder the new battery in. And then after all that you will always wonder if your repair job will hold up under real world. Fork out the $$$$'s for new ones....IMHO....
Old Jul 9, 2016 | 12:23 PM
ssmike56's Avatar
ssmike56
Does anyone know how hard it is to install these on new rims? I'm thinking it would save me a little coin if the tire shop doesn't have to remove the old ones and re-install in the new wheels. I can install them myself and have them ready for just a tire swap. Might justify the extra $150 for new ones. My wife is already giving me the evil eye at the money I'm throwing at the car lately!
Old Jul 9, 2016 | 02:03 PM
4SUMERZ's Avatar
4SUMERZ
10 year lifespan seems very reasonable. I have a 2006 with 80K miles with the original sensors. I plan on replacing my tires next summer, so at that time, I will also get all new sensors. I need to have those working as I run Non Run flat tires. When I get a low pressure alarm, I need to know its reliable, and not a failing sensor.
Old Jul 9, 2016 | 02:13 PM
dmk0210's Avatar
dmk0210
On top of ssmike56's question, what is the average labor cost to swap the sensors on existing wheels?
It seems to me that preemptively changing them may not make much sense if they potentially could go 75-90k miles. I just hate to replace good OEM parts when that money could go towards something that makes a performance improvement.
Old Jul 9, 2016 | 02:16 PM
Welker1's Avatar
Welker1
When I replace the wheels on my Camaro, our local Big-O swapped my sensors over for free, was only charged for swapping the tires & balancing
Old Jul 9, 2016 | 05:05 PM
windyC6's Avatar
windyC6
There may not be any limp mode due to air pressure loss, but if your TPS goes South it will mess with the traction control system and active handling. It will usually take away the ability to shut off/over ride the handling systems.
Old Jul 9, 2016 | 07:04 PM
owc6's Avatar
owc6
No it doesn't.
Old Jul 10, 2016 | 02:03 AM
HOXXOH's Avatar
HOXXOH
No it doesn't.
I ran for months and around 8K miles with no sensors at all. Had absolutely zero problems, even at well into triple digit speeds and at the dragstrip. My DR's have no sensors, nor do my front drag skinnies and the TC works as normal.
Old Jul 10, 2016 | 02:32 AM
HOXXOH's Avatar
HOXXOH
Make the wife happy and throw the old sensors in the new wheels. You can then wait until one goes south (which may take years) before you need new ones. They are real easy to change/swap and chances are pretty good that the tire shop who's changing the tires will do it for the price of a rebuild kit. (worth asking first) If you do it yourself, I'd advise getting a "rebuild kit" (about $3 to $6 each)
Happy wife = happy life.
Old Jul 10, 2016 | 03:06 AM
  #33
Rjhctrapp's Avatar
Rjhctrapp
So my best friend bought a vette back in 1995. C4, brand new off the lot, the tpms light was always on. He'd take it in, supposedly be fixed, half a day later, light back on. Have they come a long way or what? My 2010 still has the original tpms. Still working but only 23k on the clock.
Old Jul 10, 2016 | 10:45 AM
  #34
windyC6's Avatar
windyC6
Well heck fire then.....guess they better do a call back on all the manuals that state that if your TPS has problems it can/may effect your active handling.....I knew that had to be a conspiracy !!!!.....
Old Jul 11, 2016 | 12:28 AM
  #35
HOXXOH's Avatar
HOXXOH
can/may? Which is it? There is no may. There is only can or cannot and it'd never effect, but only affect.
BTW, you can't trust the service manuals to be accurate. My '08 SM still shows several C5 parts and procedures.
Old Jul 11, 2016 | 12:37 AM
  #36
owc6's Avatar
owc6
I know, I still have a C5 steering wheel.
Old Jul 11, 2016 | 10:54 AM
  #37
Eritosthenes's Avatar
Eritosthenes
My Red is about three weeks short of 10 years old. The right front TPMS sensor battery died last month. I plan to replace the other three when I buy replacements for my winter wheels in October. CULTRAG charges $80 each. Delco OEM TPMS sensors are available on Amazon for about $30, but there's no guarantee that they're set to the correct frequency to work with a C6. Note too that the part number was changed for model year 2009 and later.
To TPMS Life Span
Old Jul 11, 2016 | 10:55 AM
  #38
windyC6's Avatar
windyC6
WOOOOAAAA....hold on there uh YODA the magnificent. I don't have a lot of faith in a lot of things that these manufactures do either....but i ain't gonna go so far to say that they will print a owners/safety manual that isn't fairly accurate....too many ops for lawsuits there. All i'm saying is that the manual states that any problems with the TPS system and the active handling system "WILL be affected" (page 4-11) in my 2006 manual. Now if you can't understand why it would be a good idea to have the active handling disconnected if all the tires are going flat and you want to argue these facts....well then.....well....there ya have it....
Old Jul 11, 2016 | 11:23 AM
  #39
HammerheadTed's Avatar
HammerheadTed
I wouldn't think it matters how much you drive, only the age from manufacturing. They probably put out a signal even on the shelf, 24x7. Would replace them after 10 years and avoid the ones from China and go with OEM.
Old Jul 19, 2016 | 07:22 PM
  #40
ssmike56's Avatar
ssmike56
I decided to keep the wife happy and re-use the original sensors. Had the tires and sensors swapped to my new wheels with no problems! I'll see how long they last now. Total cost for mounting, balancing and swapping sensors was $120.
