Stoich values
Old Jul 27, 2016 | 02:54 PM
LovellLS3's Avatar
LovellLS3
1st Gear
Default Stoich values
When my 2008 Corvette was new, straight gas was the normal gas. Now, gasohol is the standard everywhere. These require two different values for "stoich" .
Could my C6's computer simply be re- flashed so it correctly calibrates my car's air / fuel ratio ? I notice my NPP exhaust gets coked up.
Thank you . Gary Lovell
Old Jul 28, 2016 | 09:10 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Any tuner could do that for the cost of credits. The car is tuned so rich from the factory that it probably won't make any difference though.
Old Jul 28, 2016 | 09:18 AM
Don-Vette's Avatar
Don-Vette
The inner pipes on NPP will get black carbon buildup.
Old Jul 28, 2016 | 10:20 AM
extrapilot's Avatar
extrapilot
Here's some lite reading of AF ratio's & Lambda readings using all types of fuels on the market. There are lots of variables so pinning down one setting for your car maybe fruitless at best.
http://www.hotrod.com/how-to/engine/...oxygen-sensor/
Old Jul 28, 2016 | 03:17 PM
carl3989's Avatar
carl3989
USN
Interestingly here in Upstate NY the local Stewarts convenience stores have high octane gas with out ethanol. I use it all the time and appreciate vendors that do, better for the vette and other items such as lawnmowers, chainsaws and other outdoor equipment that one stores for lengthy periods.
Old Jul 29, 2016 | 06:05 AM
extrapilot's Avatar
extrapilot
I have to buy the VP racing fuel by the gallon for my small engine powered equipment which eliminates that longer storage problems with pump fuels.
Old Jul 29, 2016 | 06:44 AM
Dcasole's Avatar
Dcasole
It's normal ......
To Stoich values
