Headers
Old Jul 27, 2016 | 11:22 PM
Nightdiver's Avatar
Nightdiver
Default Headers
Thinking of installing performance headers on the Vette..2007 C6.....questions being..any HP increase? Do they need to be welded to the pipes or is there a set that can be put on with out any welding? How much increase in noise would be heard in the cockpit? Thank you for any help on this topic....
Old Jul 27, 2016 | 11:47 PM
vanlieremead's Avatar
vanlieremead
Hi
This forum is for questions for the Corvete chief engineer. You might do better in the general forum where really good folks can help.
Chris
Old Jul 27, 2016 | 11:53 PM
Nightdiver's Avatar
Nightdiver
Originally Posted by vanlieremead
Hi
Chris
Yes thanks I put it on the general forum too.....
Old Jul 28, 2016 | 08:49 AM
ngtcrlr 007 c6's Avatar
ngtcrlr 007 c6
To answer your questions... yes, headers will give you more HP. How much exactly? depends on related mods. I would say, do a CAI as well. More air in , more air out is the key. Yes it will make more noise/ drone. I have a 2007 as well, Did the LG long tube with hi-flow cats , x pipe and Borla muffs out back. K & N Cai and tune gave me approx 27 hp. Hope this helps..good luck.
Old Jul 28, 2016 | 08:55 AM
wayback's Avatar
wayback
They all bolt on. You will need a tune to get the most benefit out of them and to turn off the rear O2 sensors.
Old Jul 28, 2016 | 09:32 AM
I say NA to boost's Avatar
I say NA to boost
I went with Hinson for mine and I love them, new they're $829 shipped to your door, but you could easily find some used for cheaper. I'll add the link for you below. They bolt right on and require no welding.
heres a sound clip with some B&B NPP catback.
https://drive.google.com/file/d/0BzO...ew?usp=sharing
heres a link to Hinson
http://www.hinsonsupercars.com/p-861...es-silver.aspx
Old Jul 28, 2016 | 09:33 AM
Orion2011's Avatar
Orion2011
I've heard 20 to 30 HP with a tune many times on this forum.
Old Jul 28, 2016 | 09:36 AM
irok's Avatar
irok
Default this
there is basically no increase in noise in cockpit if you get a set that is catted and keep the stock mufflers
Old Jul 28, 2016 | 09:37 AM
Garry in AZ's Avatar
Garry in AZ
Getting them ceramic coated will reduce underhood temps somewhat, and keep them looking good as well.
Garry
Old Jul 28, 2016 | 10:31 AM
Orion2011's Avatar
Orion2011
Garry
The biggest downside of headers is the heat with can damage near by components. So IMHO ceramic coating is a must.
Old Jul 28, 2016 | 11:10 PM
Nightdiver's Avatar
Nightdiver
Taking your advice with Hinson's, they do seem the part.....really thank you for that one....
To Headers
