Puzzled
Old Jul 29, 2016 | 11:08 PM
dklonewolf's Avatar
dklonewolf
6th Gear
Default Puzzled
Hi Tadge. Thank you for allowing me to join this page. On to my problem. I recently purchased a 2006 base model coupe. Everything worked great as far as interior switches and gauges and such. All of a sudden I went to lower my passenger window and it won't go down using the passenger side switch. It goes up fine with that switch. It works good going up and down using the driver side switch. I don't understand why it stopped all of the sudden and never worked again with that switch. Any ideas would be great fully appreciated. If it's just a matter of a new switch no problem but I hate to tear that apart to find it might be something else. Thank you in advance for the help.
Old Jul 30, 2016 | 07:49 AM
jvp's Avatar
jvp
"Ask Tadge" Producer
You'll get a faster response to your question here in the C6 section.
Old Jul 30, 2016 | 07:59 AM
Welker1's Avatar
Welker1
Congratulations and welcome to the forum. As the window works fine using the driver side switch; I would have to say the passengers side switch has gone bad. You could take the switch out, take it apart and try cleaning the connectors and see if that works. Personally, I'd just order a new switch and replace it. Good luck with the repair and enjoy the new ride
To Puzzled
