Diff Fluid help.
Old Jul 31, 2016 | 04:38 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Originally Posted by Chibullies
Yea, that sounds like mine...along with some other not so super sounds.
Little grinding here and there.
How dangerous do you guys think it is driving the car like this?
Considering i would be using the highway simply going straight..no turns. (Clunking noises only happen on slow turns)
Weighing my options until these parts departments open tomorrow
See my post #12.....the clunking noise is caused by the diff clutches releasing abruptly. I believe if you continue to drive long distances with the incorrect diff fluid installed, you may irreparably damage the clutches.
Old Jul 31, 2016 | 06:41 PM
CMY SIX's Avatar
CMY SIX
Royal Purple Syncro-shift
Old Jul 31, 2016 | 07:40 PM
gsflyer2011's Avatar
gsflyer2011
Isn't that for manual transmissions, not rear ends?
Old Aug 1, 2016 | 07:46 AM
BlindSpot's Avatar
BlindSpot
I wouldn't drive it a couple hundred miles if it were mine, but sounds like you're in a pretty tough moment with a physical move.
As Bruze stated above (and I did too). Don't bet against the engineering recommendations for fluids. Falling for some marketing spiel that an aftermarket fluid is as good as or better than the factory spec is just crazy. It's like using one's intuition to challenge engineering.
The diff fluid formula must be important BC GM engineering has adjusted it twice. since C6 introduction.
Old Aug 1, 2016 | 10:40 AM
hrt vlv's Avatar
hrt vlv
Check axle nuts also. swaybar end links.
Old Aug 2, 2016 | 04:27 PM
Orion2011's Avatar
Orion2011
I used the Mobil 1 75w90 LS in mine and all is well. Be careful there is a non LS version of the Mobil 1.
Old Aug 2, 2016 | 05:35 PM
windyC6's Avatar
windyC6
Sounds like its time for a good "Top Tear" differential fluid.......sorry, couldn't resist.
Old Aug 2, 2016 | 05:40 PM
Red08's Avatar
Red08
Originally Posted by HBsurfer
Try figure eights first to mix the oil they installed. If the noise does not go away, buy three bottles. Jack the car up level and just drain and fill (you will not use all of the third bottle). Do the figure eights again.
I did mine a couple of years ago with GM Dexron. This was the first time I ever changed the diff fluid in any car. It was VERY easy to do. I drained exactly 2 quarts, and refilled with 2 quarts. Once done, I went out in our cul-de-sac and did a number of figure 8's. I've never had any issues or sounds etc. Trust me, it's an easy job to do.
Old Aug 2, 2016 | 06:51 PM
beachcomber's Avatar
beachcomber
How did it all work out?
Old Aug 2, 2016 | 06:58 PM
silver94lt1's Avatar
silver94lt1
I'm having the same issue with my 05. Does anybody have any tricks to getting the drain plug off because the drain plug on the 05 is blocked and you really can't get to it with ratchet.
Old Aug 2, 2016 | 07:11 PM
wfoZ06's Avatar
wfoZ06
I am towing from Texas a trailer with my 08 Z06 while on a 5 month road trip so I stopped at a shop outside of San Fran and bought Amsoil severe gear 75-90 and additive for the rear end and synthetic ATF for the tranny. I found a shop in Napa to replace the fluids and noticed a difference immediately with smoother shifting.
Old Aug 2, 2016 | 07:13 PM
BlindSpot's Avatar
BlindSpot
Yes, I published this before but unable to find it. Take a look at the pics. Cut a piece off of a 10mm allen key (about 20mm long {a strong 3/4"}), round the six edges on two sides. Use it as a special tool with a 10mm box wrench.
Old Aug 2, 2016 | 07:29 PM
  #33
silver94lt1
Thank you! What did you use to cut the Allen key?
Old Aug 2, 2016 | 07:34 PM
  #34
BlindSpot's Avatar
BlindSpot
I have a dremel tool with a small 1.5" dia cutoff disc. They sell them in packs at Lowes or HD, but you need the arbor too. Be CAREFUL with this little cutoff wheel. Cut half way through either side instead of all the way on one. Clean it up on a grinding wheel. Keep the piece cool while cutting. If you overheat, the cut slot will expand and grab the wheel.
Old Aug 2, 2016 | 08:07 PM
  #35
windyC6's Avatar
windyC6
Originally Posted by blindspot
i have a dremel tool with a small 1.5" dia cutoff disc. They sell them in packs at lowes or hd, but you need the arbor too. Be careful with this little cutoff wheel. Cut half way through either side instead of all the way on one. Clean it up on a grinding wheel. Keep the piece cool while cutting. If you overheat, the cut slot will expand and grab the wheel.
and wear safetey glasses !!!!!
Old Aug 2, 2016 | 11:09 PM
  #36
silver94lt1
Ok I will go grab one and try it because I really need to change it and I don't feel like paying for something that's so easy to do ONCE I remove the drain plug haha!
Old Aug 2, 2016 | 11:29 PM
  #37
HBsurfer's Avatar
HBsurfer
Make sure you remove the fill plug first. You don't want to drain the oil and then find out the fill plug is stuck.
Not a likely scenario but it is possible. Just a little tidbit I learned on the forum and thought it should be passed on once again.
To Diff Fluid help.
Old Aug 3, 2016 | 01:27 AM
  #38
silver94lt1
Yea I was able to get the fill plug off but I just had trouble with the drain plug because of the clearance issue. Thanks for the info!
Old Aug 3, 2016 | 08:24 AM
  #39
weathermaker's Avatar
weathermaker
I used a hack saw. Even if the cut is not perfect it can be used with the factory end into the plug.
Old Aug 3, 2016 | 09:16 AM
  #40
Orion2011's Avatar
Orion2011
I just used one of these.
