Picked Up A Lift for The Vette- LR-60P (Pics and Specs)
Picked Up A Lift for The Vette- Bendpak LR-60P (Pics and Specs)
I picked up a used lift a Bendpak LR-60 P from another member on Saturday for the Vette - here are some specs: This thing works awesom
I have wanted and needed a lift for quite some time and I ended up getting this one for $875 from Rod (thanks Rod)
http://www.bendpak.com/car-lifts/spe...ts/lr-60p.aspx
Lifting capacity: 6,000 lbs. / 2,722 kg
Max capacity front axle: 3,000 lbs. / 1,361 kg
Max capacity rear axle: 3,000 lbs. / 1,361 kg
Max lifting height without blocks: 26" / 660 mm
Max lifting height with 1-1/2" blocks: 27-1/2" / 698-1/2 mm
Max lifting height with optional 3" blocks: 29" / 737 mm
Overall pad length: 53" / 1,346
Overall width: 70-1/2" / 1,791 mm
Overall length: 82" / 2,083 mm
Lowered height: 4" / 102 mm
Lifting time: 35 sec
Lift pad dimension: 18" x 52" / 457 mm x 2,591 mm
Motor: 115/208-230 VAC / 50/60 Hz. 1Ph*
Shipping weight: 814 lbs. / 370 kg
Shipping dimensions: 82" x 70" x 20" / 2,083 mm x 1,778 mm x 508 mm
I will take a Video tomorrow and post it up too
Pics below
Thanks,Matt
Pics below
Thanks,Matt
Rik O'Shay (08-01-2016)
Pics below
Thanks,Matt
Pics below
Thanks,Matt
No not scary, it has the dead man locking post in the middle, it's way better than jack stands.
Way safer to lift now too. I changed the motor in my C5 on jack stands and a million other things and i would of loved to have this through all those mods!
Thanks, Matt
Thanks, Matt
The rocker savers come down about a 1/2" or more to protect the underside of the Vette from speed bumps, steep driveways, etc.
The lift itself also comes with additional square 1 1/2" rubber pads to put under it for extra lift and placement - however those rubber pads would still come into contact with the Rocker Savers should I use them
Thanks,Matt
Received 1,675 Likes
That would be nice to have!
Congrats!
What's the drive over height?
It looks like that it might pose a problem for wide body C6 that has a ZR1 type splitter on the front. Especially if lowered.
You would have to see it in order to actually understand how much room there is - the front is fully open and the small cross bar in the front can be removed if desired!
If you really look close and not just a quick glance you will see it for yourself -
However "IF" you need more room to work on the rear I can either turn the lift around or just back the Vette in the garage, it is that simple!
Thanks,Matt
Thanks,Matt
I open the door and get out, I am not FAT or anything like that, there is plenty of room. Perhaps it was just the picture.
Thanks,Matt
