Welding
Old Aug 1, 2016 | 04:45 PM
nenji01's Avatar
nenji01
Default Welding
anyone here welds or is a fabricator?
what would you guys recommend to start off at when learning how to weld, i want to be able to tig weld and custom fabricate simple stuff, piping brackets ect
Old Aug 1, 2016 | 09:42 PM
cclive's Avatar
cclive
I would check out a community college or trade school nearby as welding is offered at many...
Old Aug 1, 2016 | 09:51 PM
Red Devil Z51's Avatar
Red Devil Z51
what he said
Old Aug 1, 2016 | 11:46 PM
Garry in AZ's Avatar
Garry in AZ
I have a couple of decades of hobby welding (car chassis, motorcycle frames, sheet metal repair, and just general fabrication) behind me, so maybe I can answer a few questions... I do not pretend to be any sort of expert weldor, but I have MIG and TIG machines and some experience, gained mostly by making mistakes. When I began welding a TIG machine was called a Heliarc... back when the common shielding gas was helium.
If you have never welded before, learning to MIG or "GMAW" weld is by far the easiest welding format to learn, and become more or less proficient in, fairly quickly. TIG or "GTAW" welding is more difficult, and requires a bit more skill, practice and patience.
The vast majority of basic fabrication (like your piping and brackets) can be done with a MIG welder, including welding aluminum. (You'll need an attachment called a spool gun for MIG welding aluminum)
If you plan on doing a lot of highly visible welds, like bicycle frames or metal sculpture, a TIG machine allows better heat control and can do nicer looking raw welds. However, to TIG weld aluminum, you will need a fairly expensive machine, that has AC welding operation.
I'd suggest you begin with MIG, and see how your requirements develop, and then maybe you will want to add a TIG to the mix. There are multi-function machines that will MIG, TIG (DC only) and arc weld, but they are all a bit of a compromise.
Finding local welding classes is a great idea, as they will teach you some of the fundamentals and "do's and don'ts" of welding. For example, never using the same wire brush on steel and aluminum, or why using gas shielding will result in cleaner welds than using flux core wire. However these classes are usually designed for folks who are looking for a career rather than a hobby, and can cost several thousand dollars in tuition.
Hope that helps,
Garry
Old Aug 2, 2016 | 07:19 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Garry
This is good advice. If the local high school has trades courses, they may have adult education, and they are usually much cheaper night classes.
Have fun, it's a worthwhile skill to learn.
Old Aug 2, 2016 | 08:03 AM
funx600's Avatar
funx600
2017 C7 of the Year Finalist
Here are the industry's top tier
welding schools in the USA:
•Lincoln Welding Training and
Lincoln Motorsports welding course
•Hobart Institute of Welding Technology
•Tulsa Welding School
Old Aug 2, 2016 | 10:37 AM
windyC6's Avatar
windyC6
Oh No...!!! Not just Top Tier gas....but Top Tear welding schools too ?? !!! Now we've done it.... To the OP....be sure you get an accurate def of "duty cycles" before buying any unit. This is easy to understand, but some people muck it up in their explanation.
Old Aug 2, 2016 | 10:53 AM
JerryC5's Avatar
JerryC5
Cruise-In I Veteran
Cruise-In II Veteran
Hope that helps,
Garry
I went to welding school at night at the local technical high school. it was cheap and I got to learn both MIG and TIG.
Old Aug 2, 2016 | 11:16 AM
funx600's Avatar
funx600
That was very "brazing" of you...
To Welding
