Can you listen to the Pandora App on your smart phone and get the sound to come through the radio speakers? If so, then how? I have an '11 Grand Sport with Nav. I see a USB port in the console.
I think an iPhone/ipod works thru the USB. Do you have a 3.5 mm jack next to the USB? You can plug into that using the headphone jack on the phone and it should work.
This works without killing your battery using Bluetooth.
Purchase a good 3.5mm male to 3.5mm male cord and plug one end in your cell phone headphone out jack and the other to the 3.5mm input jack next to the USB inside your console.
Turn on the radio and open up the PANDORA APP.
Play your favorite station and it should project through your speakers. If not, make sure your radio is set to AUX and the volume on your phone is turned up.
Be advised quality and/or volume output from Pandora may not be as high as CD quality, FM quality, or XM.
I have a 11 Grand Sport and all of my music ( tunein, Pandora, iPod )plays thru the usb and also charge the phone at the same time iPhone 6s using the fire to usb connector.
