Help...stranded
Old Aug 14, 2016 | 02:32 PM
ksurfer2's Avatar
ksurfer2
Default Help...stranded
Stranded at auto parts store. Car has been slow to Starr. Came to get battery checked. Now when start button pressed...only one click then nothing. Battery tests good. Same click with jump box.
Old Aug 14, 2016 | 02:38 PM
R_W's Avatar
R_W
Check your starter solenoid for a destroyed / cracked terminal.
(Passenger side, between the header and the engine.)
Old Aug 14, 2016 | 10:20 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Hopefully, you made it home by now...
The simple/easy things to check are the battery terminals, be sure they are tight. Don't over-tighten the goofy little nuts and definitely don't remove them, just try to twist/wiggle the terminals to see if they are loose. If loose, you can take them off and use small pliers to bend the "collar" inward a little to snug it up, or just wrap a piece of aluminum foil over the post to get home.
Old Aug 14, 2016 | 10:29 PM
Dano523's Avatar
Dano523
If you need to replace the starter solenoid,
https://www.amazon.com/Premium-Quali...iglink20400-20
Old Aug 14, 2016 | 11:30 PM
4SUMERZ's Avatar
4SUMERZ
Thanks for the info
To Help...stranded
