ok smart ones, I have a 05 m6, its got a air raid cai, lg motorsports headers, no cats, corsa x pipe and axle back, and a dyno tune. car put down 375hp 393tq. im getting my heads ported and polished and a cam, what cam not sure. im wanting to get to as close to 500 to the wheels as possible n/a. and it still be very streetable. am I looking for to much out off a port and polish and cam? and I would like some advice on cams, im not real cam savey.. and what else should I get with it, push rods, rockers? any help is greatly apprieciated...
Yes, if you get a new cam or different rocker arms. Make sure you buy the best valves and guides available. There are a lot of Chinese valve train parts out there that will fail due to inferior alloys.
With a new cam, you will want new timing chain,lifters,dual springs and retainers,push rods and gasket set. I would also have the heads ported and polished with 3 angle valve job. Have your valves checked and polished (you can even machine the heads for larger valves). I would also change the intake for more flow and depending on cam bigger fuel injectors possibly. I would contact Lingenfelter for information on their cam packages.
Are you going to be doing the work or have it done? If having it done at a shop, I would get serveral quotes and just see what the shops say. I'm betting getting to 500 is going to be hard and expensive.
