Disconnect battery then get power window issue
Old 08-29-2016, 11:01 PM
gp56
Support Corvetteforum!
gp56's Avatar
Default Disconnect battery then get power window issue
I haven't disconnected my battery too frequently, only having done it 3 times in the past 2 years. Each time when the battery was reconnected the drivers side window would not go up or down when pressing the switch. Passenger side works fine from drivers side control. If I slam the drivers door the window then operates normally and I never have the issue again. What could be causing this?
Old 08-29-2016, 11:12 PM
owc6
owc6's Avatar
Received 4,192 Likes on 2,681 Posts
Have you tried initializing (re-indexing the windows)?
It needs to be done every time the battery is disconnected.
Old 08-29-2016, 11:28 PM
gp56
gp56's Avatar
I can re index once the drivers window responds.
Old 08-30-2016, 09:37 AM
Landru
Landru's Avatar
Received 1,047 Likes on 821 Posts
Need to find out if this is a issue or an electronic glitz.
If slamming door makes window work, re-index immediately and see if it holds. If it doesn't might be a failing regulator w/ no link to disconnecting battery. Weirder things have happened.
Old 08-30-2016, 04:00 PM
gp56
gp56's Avatar
Once I slam the door to get window to work it performs flawlessly until the next time I have to disconnect battery.
Old 08-30-2016, 05:01 PM
Landru
Landru's Avatar
Weird, thought you'd have to first slam door before it did anything.
A loose connection?
Having to slam door's somewhat a clue, same w/ a failing regulator.
IF it works now then leave it alone & leave battery connected, motor on.
IF either of above (loose connector/reg) begins giving problems it'll only worsen as time goes on & force your action.
In the meantime you've a functioning window, pretty fortunate in the world of C6. When something goes it's usually immediate often leaving one stuck wherever they are.
To Disconnect battery then get power window issue
Quick Reply: Disconnect battery then get power window issue
