C6 fault code access
Old Sep 3, 2016 | 03:33 PM
autocolor's Avatar
autocolor
Default C6 fault code access
is it possible to pull c6 fault codes via the dic like on the c5? if so what is the process please
thanks
Mike
Old Sep 3, 2016 | 03:38 PM
autocolor's Avatar
autocolor
Default C6 fault code retrival
is it possible to pull C6 fault codes via the DIC as on a C5? if so what is the process please
Mike
Old Sep 3, 2016 | 03:51 PM
RicK T's Avatar
RicK T
No.
You need a scanner.
Old Sep 3, 2016 | 03:55 PM
jft69z's Avatar
jft69z
No.
Old Sep 3, 2016 | 04:27 PM
Vette_DD's Avatar
Vette_DD
The process is to use a code reader.
Old Sep 3, 2016 | 04:30 PM
Vette_DD's Avatar
Vette_DD
Asking the question more than once is not going to change the answer.
Old Sep 3, 2016 | 04:38 PM
autocolor's Avatar
autocolor
Sorry about posting twice but it was via the phone and the post wouldn't log properly so tried again
Mike
Old Sep 3, 2016 | 08:47 PM
Vette_DD's Avatar
Vette_DD
Mike
Thanks for the explanation.
Old Sep 3, 2016 | 08:55 PM
LMB-Z's Avatar
LMB-Z
Take it to your local auto parts store. They should be able to pull them for you.
Old Sep 3, 2016 | 09:44 PM
owc6's Avatar
owc6
Or if you are an OnStar subscriber, they can read them for you.
To C6 fault code access
