Correct me if I'm wrong!
I've been doing a lot of reading and looking at used C6 convertibles online.
I've gotten quite an education, and want to verify, that I'm understanding the difference of the various options over the base model, especially the suspension!
I have a limited budget for the car(maybe I shouldn't be looking at Corvettes), and will be using the car mostly for touring.
The year range that I'm looking at is from 05>08, and my thinking is to buy either a base, or Z51, and to stay away from the F55, only because of the cost to repair and replace the shocks with oem. I like to keep my cars bone stock, and won't spend close to $5K on a car that might cost 25K!
So my question is, if I do find a great deal on a car with the Z51option, am I correct in understanding, that if I need to replace the GY high performance tires, the wheel size is the same as the base car, and I can use the less expensive tires that come on the base car?
And does the same hold true for the shocks.
I understand that if I buy a base car, I can always improve the handling by installing the Z51 sway bars, and shocks in the future?
My wife and I are retired, and my leadfoot days are over, but I still enjoy a car that has cojones, and a rag top! And it must be a 6sp.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
While you're correct, the F55 shocks do cost a lot, they're now down in the $500 each range.
Yes, the above is correct. Plus, there are quite a few runflat and non-runflat choices for tires.
Yes, the same holds true for shocks.
Yes, correct.
Yes, correct.
Good luck, happy hunting and come back on when you have your new car.
marinablu67 (09-12-2016)
Yes, you can place the tires with any brand. If you are looking at 05-08, they most likely will not have the OME tires on anyway.
Again, if you change the shocks on a Z51 oprioned car, you will lose the Z51 handlong to an extent.
Final, if you are buying the car for limited use and not planning any high performance driving, such as autocross or track use, I would not even worry about a Z51. The ride is a lot rougher then the base suspension. If the price is right however, and you find a car that fits your budget and has what you want with the Z51,then I would buy it.
I wouldn't rule out a C6 with the F55 suspension if everything checks out OK at the time of purchase. The F55 (Magnetic Selective Ride) are very reliable shocks and should last the life of the car in 95-98% of cars (well over 100,000 miles I suspect). I rarely have heard of problems on the forum. (You are right though, that if they did fail they are expensive to replace, BUT you could always change to less expensive shocks [not F55] if that were to happen)
That's what I have and if your going to use it for touring, the F55 is a GREAT suspension. Rides great and you can choose 'Touring' or 'Sport' modes.
If not the F55, I would say the base suspension would be better for touring. The Z51 suspension will give you a much stiffer ride.
If you get the base or the Z51, you can always change the shocks later if you don't like the ride.
I agree with all comments above. I would add that you mention using the car primarily for touring. My interpretation of that is long tours with some spirited cajone runs here and there. Having said that, Z51 is definitely not ideal for you. I strongly suggest a 3LT equipped car, F55, '08 - in that order.
3LT is "fully" optioned with all the right stuff for touring.
F55 magnetic ride is awesome.
08 is first year for the absolutely inspiring and unbelievably venerable LS3
Good luck !
Good luck !
bgspot (09-13-2016)
All c6 besides 05 autos are 6 speed. Did you mean you want a manual? Auto cars are still 6 speed.
Received 1,116 Likes
Don't pass up a deal just because it has mag ride F55. The shocks are designed to last the life of the car. May not be long before they are standard equipment on all sports cars.
My car has the Z51 option, and I am "older" (retired), but I don't really think the car rides all that rough, at least on decent roads. It's a bit bumpy over speed bumps and the like, but for highway cruising it's not objectionable. Could be that I'm just used to it.
I also agree with the comments that have been made. I have an 05 convertible with the Z51 pkg. Purchased the car used with minimal knowledge of suspension issues. I like to do some cruising and touring with an occasional kick in the *** to feel that power but I really dislike the ride quality of the Z51 pkg. I know I can and probably will make some changes to improve things but my next vette will have the F55 suspension so I can do the adjusting to what I like.
Good luck on your search and try to buy the newest you can afford to take advantage of any updates made
The OPs last line stated he's retired. I assume that means he is in my age group. I don't tour with my Z51 Vette. In fact, if I am going to take a road trip I have 3 other cars, all of which would likely be chosen for a road trip before the Vette. I love the Vette for WHY I have it...and it ain't road trips. If my Vette didn't have Z51, then it might move up from #4 to #3 or 2 for a road trip.
In my opinion, the F55 is way better than the Z51 because you can't adjust the ride on the Z51. Good luck.
Yes I did mean manual!
We're down to one vehicle now, a Silverado 2500HD with auto. I had to junk my last manual car a couple of years ago because of rust, a Wrangler, and really miss a stick.
Thank you all for the response!
These cars really maintain their value over the years, especially for a nice clean low mileage, 1 or 2 owner, clean Carfax!
I think the 08 3LT equipped car, with the LS3, and F55 suspension may go above my budget, especially in Florida, but miracles can happen!
I won't buy anymore cars that are in the NE, or originally were delivered from a dealer in the NE! I've lost count to the amount that I had to junk, because they wouldn't pass the NY safety inspection! Chassis, what chassis?
I know the Corvette may be different, because most owners don't take them out in the winter, but I much rather have a car that lived in the South!
From what everyone is saying about the Z51, and not having a chance to drive one, this is why I asked about the car being modified in reverse. If I find a great car/deal, it seems just changing the tires and shocks would "improve" the ride, and not cost a fortune down the road if I didn't like the ride! Saying that, I drive a HD pickup now
Received 3,629 Likes
2016 C6 of Year Finalist
The nay sayers will chime in but don't overlook a nice '05. I put 40,000 trouble free miles on my '05, 6spd, 1SB, Z51 vert. I made several 1700 mile trips in the car and got out with the same silly smile I had when I got in.
Do your search, do your due diligence, and buy the car that best fits your budget.
In fact, check it out...
[URL="http://www.autotrader.com/cars-for-sale/vehicledetails.xhtml?endYear=2005&zip=33 101&transmissionCode=MAN&maxPrice=24000& transmissionCodes=MAN&showcaseListingId= 429854213&mmt=%5BCHEV%5BCORV%5B%5D%5D%5B %5D%5D&vehicleStyleCodes=CONVERT&modelCo de1=CORV&startYear=2005&makeCode1=CHEV&s howcaseOwnerId=65843519&firstRecord=0&se archRadius=0&listingId=430897248&Log=0"]
Get the GMVIS for any Corvette you are thinking about. A GM service writer will print one for free.
Hmmm, the link doesn't look right. The car is on autotrader at Elite Autos in Port Orange, FL.
Hmmm, try this link:
http://eliteautofla.com/14902/2005-C...te-Convertible
It's ironic!
I saw this car this morning, and really liked it! I was looking at the description and photo saying it had 80K, but when you read the supplied Carfax, it had 147K on it.
I called him this morning and he said it was Carfax's mistake, and was going to correct it. Looking at it now, it hasn't changed, and I'm not sure about the Z51 option, even though it's listed. Isn't 1G1YY a base car?
In any event, I'm going back down next month whether I sell the house or not. If he still has it, I'll take a ride. I'm just starting to look.
Thanks for the link!
my two cents
Yes, it's a "base"...which usually means narrow body. Z51 is a performance/suspension option on the base car. It was later incorporated into the GS package in 2010.
z51 or not?
It's ironic!
