Led Interior lights
Old Sep 21, 2016 | 05:26 PM
Sunsetter's Avatar
Sunsetter
4th Gear
Default Led Interior lights
Hello I recently swapped my overhead map lights with Led replacements. ( 2005, C-6 Coupe) I also replaced the footwell lights for Led strips. I am now noticing that once the timer powers down the lights after closing the door that they are not shutting down completely. I can see a dim glow from all 4 locations . I pulled a light and put a volt meter in the socket. At rest, there is still 7.1 volts available. I replaced the original bulb temporarily which exhibited NO signs of any glow. Someone wrote elsewhere that there is always power left on and the source but not enough to power up the incandescent bulbs and since the LED's take less to operate they can work with 7 volts.
Do you think that is the case or do you believe there is a malfunction in the power down circuit? BTW, I am keenly aware of the dash switch that we ALL have bumped thus leaving on the overheads.
Thanks a ton. Ed
Old Sep 21, 2016 | 10:04 PM
Frankie15's Avatar
Frankie15
Mine do the same thing. I read numerous posts saying that this is normal and doesn't draw enough power to be a problem.
Old Sep 22, 2016 | 12:34 AM
Sunsetter's Avatar
Sunsetter
4th Gear
Thank you Franke, ED
Old Sep 22, 2016 | 06:21 AM
Dcasole's Avatar
Dcasole
So do mine , they eventually go out......
Dave
Old Sep 22, 2016 | 07:37 AM
User Omega's Avatar
User Omega
This is normal. If it gets annoying you can add a 1k ohm 1/2w resister but I wouldn't and have not on anything I own.
Old Sep 22, 2016 | 07:53 AM
BROCKYJACK's Avatar
BROCKYJACK
I changed all the interior lights to LEDs on my 2011 about two years ago. Months later I read a post on the forum similar to yours. Went out o the dark garage and sure enough could see a dim glow from the map lights. It has never been a problem. The LEDs do not draw enough current to cause a drain and be a problem. They certainly do look better. Also changed backups and installed Eagle Eye tail lights, JWM fog lights and Radio Flyer switchback DRLs.
Old Mar 5, 2017 | 02:25 PM
nick14003's Avatar
nick14003
completely normal, no solution
Old Mar 5, 2017 | 03:56 PM
449er's Avatar
449er
CF Community Team
Thanks a ton. Ed
I too over the winter replaced all of my interior lights with leds, I like the whiter color of the lights & have had no issues with them so far
Old Mar 5, 2017 | 04:07 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default LED Interior Lights
As far as the map lights the better quality 194 bulb will not stay on dim. I believe I got mine from JWM Motorsports. $33.00 shipped.
Old Mar 6, 2017 | 02:46 AM
Ahrmike's Avatar
Ahrmike
did you change out the footwell lights too?
Easy solution for this is to leave one of the two passenger footwell lights as a non LED.
Old Mar 6, 2017 | 09:38 AM
2008 Corvette
Yes. I changed out the foot well lights also. However I did NOT change out the Glove Box light but the inexpensive 194's I put in the Map Lights stayed on dim. JWM light package much better LED's for the Map Lights. Problem solved.
Old Mar 6, 2017 | 11:27 AM
LS WON's Avatar
LS WON
Thanks a ton. Ed
It's normal. When you park your car in a dark garage you will notice it even more. Mine has been doing it for 10 years now with no problems. The hood light whether LED or regular won't make a difference plus if it is an LED it will only light on one side only.
Old Nov 13, 2019 | 07:42 AM
C6-427-Heaven's Avatar
C6-427-Heaven
1st Gear
Default Thanks!
1st post for me after being a long-time viewer/reader of this forum.
I fussed with my LEDs not going completely out for weeks until finally calling it quits!
That is until I came across this thread.
I too figured out if I leave a footwell light original, everything is fine. However, I’m using colored lights and leaving one white ruins the effect.
Did only buy the cheap bulbs (twice!) and will pick up some JWM bulbs and cross my fingers.
If they still remain dim, I won’t stress about it.
Thanks all!
Old Nov 13, 2019 | 12:08 PM
68/70Vette's Avatar
68/70Vette
I think LEDs would be recommended for the center mirror assembly. There's a lot of electronics in there and the stock incandescents can cause unneeded heating of the assembly.
Old Nov 13, 2019 | 04:36 PM
LMB-Z's Avatar
LMB-Z
Mine do the same thing, but they never go out. I also keep my car on a battery maintainer. The map light stays on all the time, very dim. The lights in the rear compartment do go out after a period of time as do the ones in the footwells.
Old Nov 13, 2019 | 06:12 PM
Legend Rider's Avatar
Legend Rider
Just went out & locked up the garage, open both doors on the Vette & then closed them. All of my red interior lights went out completely after a few seconds. the only blub that is not LED RED is the glove box, which still has the original bulb install. Just to much of a pain in the *** to get to. Go Figure!
Old Nov 13, 2019 | 06:32 PM
2008 Corvette
Originally Posted by ModifiedVettes
We sell LED kits (with a forum discount) and all of our C6 kits do this. It is normal and after a while, they WILL go out.
I have had them in my personal car for years without the issue of drain, etc. Let us know if you have any questions. Here to help!
. See post # 11. Much better quality bulb will NOT stay dim after timeout.
To Led Interior lights
Old Nov 13, 2019 | 07:01 PM
Iceaxe's Avatar
Iceaxe
I bought these and they don't stay on, are bright, and have none of the other LED issues everyone is always bitching about. Best of all they were very reasonably priced. YMMV
https://www.ebay.com/itm/13x-White-L...6/162399014611
Old Nov 13, 2019 | 07:14 PM
Iceaxe's Avatar
Iceaxe
The glove box light is very easy to replace if you remove the entire light assembly out of the front and then swap bulbs. It takes all of 3 minutes and involves no strange contortionist moves or freak fingers.
It's been a while since I did mine but if I remember correctly the entire push button light switch assembly comes out the front. There is a tab on each side of the switch and you squeeze the switch and the entire assembly pulls out of the front at which time replacing the bulbs is simply unplugging and plugging back in.
Old Nov 14, 2019 | 11:40 AM
2008 Corvette
Default Led map lights
. I have from JWM Motorsports led 194 in my map lights and after timeout they go off completely. So not all C6’s do that
