Weird tire pressure error
Old Sep 21, 2016 | 07:56 PM
LsLegacy's Avatar
LsLegacy
Default Weird tire pressure error
So, I was driving back from work doing 35 mph, and the "Front Right Tire Pressure High" message came up, I checked, it was at 47 PSI.... I haven't filled the tires at all, the tires are new as far as I can tell, the tread looks 80%+, anyway, I was going and it went back down to 32 psi, as I approach my neighborhood, it was going between 33 and 32...
So, my question to you guys, has anyone experienced this? Is this a sign that the tire monitor could be going bad? I'm currently googling and I'm not seeing anyone ever having experience this.
Old Sep 21, 2016 | 08:06 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
If in doubt, check the tire pressures with a good quality gauge and compare it to what it shows on the DIC for each tire.
If there is a big difference, you have a bad TPMS sensor on that wheel.
Easy Peezy ....
Old Sep 21, 2016 | 08:07 PM
extrapilot's Avatar
extrapilot
I have to assume when you said that you checked the tire pressure, it was using a tire gauge? If so, you may have something going on with your brake system or wheel bearings transferring the heat to the tire, but what ever happened, it corrected itself. I've seen brake calipers start seizing and creating a lot of heat build up and affecting the tire pressure.
If you mean you check the pressure assuming the monitor was correct, then that would be another story.
Old Sep 21, 2016 | 08:12 PM
LsLegacy's Avatar
LsLegacy
I'll clear up the confusion, sorry bout that.
I just looked at the hud. When it told me the error, I immediately hit the button to get to the front tire pressure portion of the hud. Left was 34 psi, right was 47. I was going to stop and look at the tire to see if anything was wrong, and it went back down to 32 psi. Then when I got in my neighborhood, the tire went to 33 psi.
I didn't exceed a speed of 50 on my commute. Between the 35 mph zone that I came to when the error popped up and the neighborhood, I only went 45 mph when the limit changed.
Old Sep 21, 2016 | 08:14 PM
J3TVETTE's Avatar
J3TVETTE
TPMS battery dying on that wheel
Old Sep 21, 2016 | 08:18 PM
extrapilot's Avatar
extrapilot
Thanks for the clarification.
As others have suggested, battery issues. How old are the TPS's
Old Sep 21, 2016 | 08:19 PM
Turbo6TA's Avatar
Turbo6TA
Yup ....
Old Sep 21, 2016 | 08:24 PM
LsLegacy's Avatar
LsLegacy
I couldn't tell ya :\. I just got her on Saturday. Car's a 2009 with 77K miles. The tires and wheels are new according to the dealer I bought it from. But, I doubt the monitors were replaced. So, my guess would have to be 7 years? lol
Old Sep 21, 2016 | 08:26 PM
Turbo6TA's Avatar
Turbo6TA
I would replace all the TPMS sensors ... I am betting they all will fail shortly
Old Sep 21, 2016 | 08:33 PM
damascus1986's Avatar
damascus1986
same error^ fixed itself when i pulled over. what are some good replacement TPMS sensors? link?
Old Sep 21, 2016 | 08:54 PM
LsLegacy's Avatar
LsLegacy
Was just about to ask this same question. I had a c5 and the sensors cost me too much for me to care for, but this is a little different. The c6 is something I want immaculate.
Old Sep 21, 2016 | 08:57 PM
CMY SIX's Avatar
CMY SIX
oh really? mines a 2006 I haven't replaced 1 yet
Old Sep 21, 2016 | 09:06 PM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
I have an 07 and have not had any issues with mine either, but the "expected" life for them in 5-7 years, so it is about that time.
Still, very strange behavior to go from normal to 47 psi to normal again. Sounds more like a stuck bit someplace in the data stream that fixed itself.
I would just monitor the situation and take action when the anomaly becomes more common.
But int he meantime, I would certainly check the tires with a good quality tire-pressure gauge ... technology is wonderful, when it works.
Old Sep 21, 2016 | 10:19 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
And be sure to check all 4 tires, because someone might have mis-programmed them and the "right-front" pressure is actually some other tire on the car.
Old Sep 21, 2016 | 10:32 PM
EVRose's Avatar
EVRose
You will be.
Old Sep 21, 2016 | 10:54 PM
Cherokee Nation's Avatar
Cherokee Nation
I have a 08/Z51 and my tire pressure does not show in the Hud ?....Only in the DIC!..I only use the street mode for the hud
Old Sep 21, 2016 | 11:20 PM
cclive's Avatar
cclive
My first thought also..especially on a car that is new to you. Don't go spending money on new sensors until you diagnose the problem. Check all four with a good handheld gauge. I have two sets of wheels/tires, one from 2006 and one from 2007 and all eight sensors are still fine. Once you are sure of the sensor's locations, you can easily replace one by itself if it is going bad.
To Weird tire pressure error
