Service charging system
Old Oct 7, 2016 | 12:09 AM
mossmotors's Avatar
mossmotors
Cruising
Default Service charging system
2006 c6 i got a brand new starter and solenoid new alternator checked the fuse and its still not charging i have no ideal what to do.could a wire be split or burnt somewhere.im decent with mechanical work but im giving up.i know to bring it to the dealer its gonna cost a good bit.anybody have ant solutions.electrical or whatever. Thanks in advance
Old Oct 7, 2016 | 12:25 AM
4SUMERZ's Avatar
4SUMERZ
I can offer you this Charging system PDF from the service manual. It may help you diagnose the cause.
Good luck
File Type: pdf
Old Oct 7, 2016 | 09:09 PM
tennblkc6's Avatar
tennblkc6
what's the voltage reading at the alternator at idle and st the battery at idle. also, check to make sure the ground wire on the block by the starter is tight.
To Service charging system
