2005 automatic gear selection
Old Oct 10, 2016 | 08:35 PM
soheil's Avatar
soheil
Default 2005 automatic gear selection
anyone know what the 3 , 2 ,1 under D are for?
Old Oct 10, 2016 | 08:55 PM
EVRose's Avatar
EVRose
Third gear, second gear, first gear. There if you want to shift manually. Same as almost any other car with auto trans.
Old Oct 10, 2016 | 08:59 PM
LMB-Z's Avatar
LMB-Z
fast (1), faster (2), fasterer (3) fastest (D) The silver button on top is the passenger eject button.
Old Oct 10, 2016 | 09:03 PM
soheil's Avatar
soheil
so wherd 4th gear? since its 4 speed auto. should be 1234?
Old Oct 10, 2016 | 09:24 PM
tennblkc6's Avatar
tennblkc6
4 is overdrive...it kicks in when you press the silver eject button.
Old Oct 10, 2016 | 10:04 PM
EVRose's Avatar
EVRose
Really? Are you being serious?
Old Oct 10, 2016 | 10:39 PM
owc6's Avatar
owc6
If you put it in 3, then it will start out in 1, shift to 2 and then go to 3. It won't go to 4 (D), unless you shift it to D.
If you put it in 2, then it will start out in 2 and stay there until you shift it .
Obviously if you put it in 1, it will start and stay there until you shift up.
Old Oct 11, 2016 | 09:57 PM
C6ToGo's Avatar
C6ToGo
He is just being "wherd"
Old Oct 12, 2016 | 03:09 AM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
You get one Guess! Bet he'd like to know what that button below the shifter is too. Don't tell him it's the Eject button, he might hurt himself.
Sad really.
Old Oct 13, 2016 | 11:34 AM
BigRuckus's Avatar
BigRuckus
This thread has got to be a joke...
Old Oct 13, 2016 | 01:11 PM
Vette_DD's Avatar
Vette_DD
2005 owner's manual, pages 2-25 and 2-26.
AUTOMATIC OVERDRIVE (D): This position is
for normal driving.
THIRD (3): This position is also used for normal driving.
However, it offers more power and lower fuel economy
than AUTOMATIC OVERDRIVE (D).
Here are some times you might choose THIRD (3)
instead of AUTOMATIC OVERDRIVE (D):
• When driving on hilly, winding roads.
• When going down a steep hill.
SECOND (2): This position gives you more power but
lower fuel economy than THIRD (3). You can use
SECOND (2) on hills. It can help control your speed as
you go down steep mountain roads, but then you
would also want to use your brakes off and on.
If you manually select SECOND (2) when you start the
vehicle, the transmission will drive, and stay, in
second gear. You may use this feature for reducing
torque to the rear wheels when you are trying to start
your vehicle from a stop on slippery road surfaces, or for
preventing the transmission from downshifting into
FIRST (1) in situations where a downshift would
be undesirable.
FIRST (1): This position gives you even more power,
but lower fuel economy, than SECOND (2). You can
use it on very steep hills, in deep snow or mud. If
the shift lever is put in FIRST (1), the transmission
will not shift into first gear until the vehicle is going
slowly enough.
Old Oct 13, 2016 | 02:34 PM
NOWUCME's Avatar
NOWUCME
You have a kind Heart, good reminder
Old Oct 13, 2016 | 09:25 PM
Vette_DD's Avatar
Vette_DD
https://www.corvetteforum.com/forums...conflicts.html
Any thread(s) that contain open bickering, name calling, subtle derogatory messages, "digs," personal attacks, or anything negative in nature will be closed/edited or deleted, and any participating members who post in violation of this rule, will jeopardize their posting privileges.
To 2005 automatic gear selection
