C6 Headlight Lenses
C6 Headlight Lenses
Mr. Tadge Juechter,
C6 headlight lenses are developing hundreds of small cracks that negatively alter the appearance and performance of the headlights. This is not simple oxidation, but cracks that cannot be polished out with the numerous DIY kits available at auto supply stores. It seems to be happening to nearly all C6 headlights. Some earlier than others depending on usage. Fixing the lenses using OEM parts requires replacement of the entire headlight housing at substantial cost.
Why do the lenses develop hundreds of small cracks in a relatively short period of time?
Is there a less costly way to restore the original appearance and performance of the lenses?
Will GM offer a better quality replacement lens that does not require replacement of the entire light housing?
Thank you.
Thank you.
I posted this question here in the Ask Tadge forum several months ago and got crickets. If you have deteriorating headlight lenses, this is the way forward. GM is not looking back at us.
https://www.corvetteforum.com/forums...post1593788640
My experience with the headlight lenses is limited. But, I'll share my experience.
My headlight lenses weren't crazing or cracking very much at all. However they were pitted.
My wife was cleaning the lower valance with some denatured alcohol. She got the can mixed up with Acetone. And she wiped my lenses down with Acetone. That instantly hazed the lenses to a milky white. Because I use acetone every day commercially, I knew I could polish the lenses to get them back to new appearance. No Sweat! lol
Well, I was able to accomplish the polishing task but it was much harder than I expected.
As I sanded the surface of the lens to remove the damaged surface, I realized there was some sort of coating on the lens. It was harder that I was used to for acrylic parts. But I did break thru the harder surface and the lens polished out nicely. The right lens wasn't damaged by acetone but I decided to sand and polish it anyway. I only sanded the harder coating and tried not to go thru it. It polished out good too. But it took a lot more time and effort.
I assume the coating is a protective layer. And I assume its probably some sort of poly carbonate.
I suppose the crazing could be under the harder surface, and that's why its not coming out under normal procedures. If it is under the harder surface, that surface can be removed by sanding. I don't know how long the new surface will look good with out the harder surface to protect it. But if the lens is ruined anyway, It's worth a try.
I think the OP is overstating this, big time. I think, as later posts suggest, it comes down to what has been used to clean the headlight, and the conditions the car is stored in, especially during the day. The key is keep them clean and protected. The surface of this plastic needs protection/maintenance just like the painted and other plastic surfaces on the car. Choose not to provide that protection, cleaning with appropriate products, then polishing and sealing with material appropriate products is asking for trouble.
The headlights on my 2008 C6 look as new - and I invest time on a regular basis to keep them that way.
Is there anyway to clean the inside of the Headlights with out taking them totally apart? I believe mine just need to be wiped on the inside. 2012 GS 3lt torch Red.. Thanks Bill
My 2012 headlights started having flakes of plastic coming off them after about two years. Like they were delaminating. No cracks were seen. Both were replaced under warranty at 35,000 miles. Now at 55,000 miles no issues noted on this pair
Mr. Tadge Juechter,
Thank you.
Thank you.
Another 12 GS here, slight film/haze on inside of lens. If I could just wipe with a bit of Plexus, I am thinking...
I looked at a dozen corvettes before i purchased and they all had some sort of issues with the headlights whether it were tiny cracks, faded and looking old. i got lucky with mine they are actually in pretty good shape but when you turn the headlights on you can see the light exposing all the little dings from the rocks/pebbles hitting the lenses.
My car has just slightly over 30K miles. It actually has been washed very little in 8 years as I rarely drive it in inclement weather and it stays beautifully clean. When I wash it I don't use the wrong cleaning products or tools. I still contend the material is not durable enough or we would not have this business starting up to supply new headlight lenses for what are still very late model cars.
Bottom line, it would be great for auto makers to produce for us a car with headlights that need no time from us to look and work at their best. Until our design expectations change, little chance of going back to glass.
lynnt (02-14-2017)
I hate GM for not backing up parts that should still be available. Including not fixing issues decades old like the harmonic balancer. It's clear they have not yet learned what makes customers satisfied after the bankruptcy. How does that C.E.O. keep her position? Union?
Supporting Vendor
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
There is a wealth of info here in the forums covering probably every aspect of the head lights and reasons why they are not holding up. From the best info I've got is that GM, as part of the bankruptcy/bailout, is that they [GM] would not have to supply replacement parts for these model years hence they are not available but does pave the way for people like me to lead the way for aftermarket lens and soom complete assemblies.
vcheng (02-15-2017)
Did they fix the issue on C7s? They appear to hold up better, but they may not be old enough yet. Just curious.
Do you have any insight into the durability issues with these C6 corvette headlights that you can share with the forum?
Thanks,
I haven't used this, but a few other products. Key point that often is lost - products like this only protect - which is fine, except that most plastic headlights need light to heavy corrective action before applying a sealant, wax, or special coating.
I've worked on several headlights that were brought back to new looking after light to heavy correction, some looking somewhat yellowish. No sealant, wax, nor coating will improve the look of a plastic headlight - just preserve it in it's current state.
