Tint experts
Oct 24, 2016 | 04:19 PM
Tint experts
Oct 24, 2016 | 04:50 PM
2015 C6 of the Year Finalist
That's a sign. Take it off.
Hmmm, that's an interesting tint option.
It might help if you provide a little more detail.
How did you prep the lenses prior to applying tint?
Were the tinit pieces precut or you cutting to fit?
You use heat at all during the application process?
What are you using for film application fluid?
Oct 24, 2016 | 04:55 PM
Quote:
Originally Posted by
ncvette_1FUNRIDE
I'm leaning that way.
Oct 24, 2016 | 07:04 PM
Don't need it, go ahead and remove it
Oct 24, 2016 | 07:48 PM
Actually imo I think if you tint your entire headlights it will
Match the hood area
Oct 24, 2016 | 08:45 PM
RicardoFors68
And will reduce your being able to see and be seen... another vote for removing. Oh, and it's probably illegal
Oct 25, 2016 | 11:04 AM
In spite of the critics, I had no problems with mine, where did you buy it??
NSF
Oct 25, 2016 | 12:44 PM
Not So Fast
In spite of the critics, I had no problems with mine, where did yobuy it??
NSF
It's not the tint so much (although I wouldn't do it), it's that he was only tinting the
upper portion of the headlight.
That looks off to me.
Oct 25, 2016 | 02:26 PM
ncvette_1FUNRIDE
It's not the tint so much (although I wouldn't do it), it's that he was only tinting the upper portion of the headlight.
Sure, I understand its not for everyone absolutely.
To tell the truth I didn't even notice that he was doing just the top half, why ??
NSF
Oct 25, 2016 | 02:52 PM
I can see doing it just to be different from other Corvette owners. It's questionable if you could slide it past state inspection depending where you live. If you can't get it to stick your only other option would be spray on tint. Then you would have to reason possibly replacing the lenses in the future if the tint can't be buffed off. That is if GM decides to stop making the lenses.
