windshield wiper removal
Old Nov 6, 2016 | 04:08 PM
royalcasa's Avatar
royalcasa
Default windshield wiper removal
I need to remove the windshield wipers. Do I have to purchase the special tool, they sure are tight, I cant pull them of with my bare hands.
thanks
Old Nov 6, 2016 | 04:18 PM
George's_Vette's Avatar
George's_Vette
You looking to take just the blades off or the entire arms?
George
Old Nov 6, 2016 | 06:31 PM
Red08's Avatar
Red08
I replaced my wiper blades recently with Rain-X Latititude. Very simple job.
Old Nov 6, 2016 | 06:46 PM
4SUMERZ's Avatar
4SUMERZ
thanks
http://www.corvettearizona.com/pdf/g...ust%202013.pdf
Old Nov 6, 2016 | 06:49 PM
Jmhornz71's Avatar
Jmhornz71
Go to Advance or Auto Zone they will put them on for free
Old Nov 6, 2016 | 06:53 PM
royalcasa's Avatar
royalcasa
[QUOTE=George's_Vette;1593409717]You looking to take just the blades off or the entire arms?
George[/QUOTE
looking to remove the entire arms
Old Nov 6, 2016 | 07:59 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Good question and I don't know the answer, but you can try this: On another car I had ... I think a Camry ... when you moved the arm away from the windshield about 90 degrees, it released the hold onto the splined stud and the arm could be pulled right off. Not sure if that's how it's done on the Vette though ... only the driver's side will go all the way up ... the passenger side only goes up a couple of inches for no known reason (so don't force it).
There must be a straightforward way though, even if this method isn't it.
Old Nov 7, 2016 | 04:30 PM
gp56's Avatar
gp56
Mine have come off easily whenever I have done it. I removed the nut and then rocked the assembly back and forth near the base and that was it.
Old Nov 7, 2016 | 07:21 PM
cmonkey713's Avatar
cmonkey713
To remove the entire arm, first pop the plastic cover at the end of the arm. The attachment nut is under the cover. Remove the nut and with one hand reliever the pressure of the arm portion against the windshield. Then just wiggle the attachment of the arm and it will just pop off. Now a little tip, before removing the arm mark the location of the wiper blade on the windshield with tape. When you re-install the arm you will have a definite location to position the blade on the windshield. Tip: Before reinstalling the arm on the drive post put a little lube on it so it will come off easier next time.
Old Nov 8, 2016 | 04:50 PM
royalcasa's Avatar
royalcasa
Default got it done
Ok I figured it out. no special tool needed,
1 remove plastic cover
2 remove nut
3 I tapped the area were the bolt is with a small rubber mallet
4 lift the smaller arm, then lift the hole arm of the bolt
Old Nov 8, 2016 | 05:51 PM
cmonkey713's Avatar
cmonkey713
2 remove nut
Be sure to put a little lube on the drive post so it will be easier if you need to do it again.
Old Nov 8, 2016 | 06:33 PM
royalcasa's Avatar
royalcasa
will do
To windshield wiper removal
