battery exploded!!
Old Nov 12, 2016 | 11:07 PM
nzkiwivet's Avatar
nzkiwivet
Default battery exploded!!
Just come back from a drive and parked the car up in the driveway and gave her the customary wash.i was just starting to chammy it off when it started to spit a few spots of rain so I thoughgt I would run the car into the garage to finish it off.Went to start it up and it cranked over good as and then there was an almighty bang and smoke coming out from the right hand bonnet corner,popped the hood and went to grab an extinguisher and lifted the hood up.Both battery tops were off and there was a bit of smoke/fumes etc floating around.put the tops back on and ran abit of water around to flush any fluid away which lucky there was not much except on the corner of the inside bonnet where one top must have popped up to.No power of any sort at the go button.I took the whole battery out and gave it another good rinse all around just incase.When I got the battery out the whole top has a crack across it.
Does anyone know any tricks to get the car out of park and into neutral so I can push it into the garage?it has an ac delco 85-6YR.I will get a new one and get the charging system checked over too I guess?
Old Nov 12, 2016 | 11:15 PM
bassman50's Avatar
bassman50
Glad you and the car are OK. . . .
Sound like there was an internal problem with the battery (perhaps a loose post?) or a poor external connection to the battery, a build-up of hydrogen gas, and a spark set it off. . . . Hope you're able to figure out what caused the explosion.
Steve
Old Nov 12, 2016 | 11:33 PM
EVRose's Avatar
EVRose
You will either habe to take the console apart and move the shift locking pawl manually or supply 12v at the battery cables to get it out of park.
Old Nov 12, 2016 | 11:39 PM
nzkiwivet's Avatar
nzkiwivet
was thinking about that with another battery through jumpers?guess what else I did?yes,I shut the fkn door!!!
Old Nov 13, 2016 | 12:05 AM
EVRose's Avatar
EVRose
So use the key and open the hatch.
Old Nov 13, 2016 | 12:14 AM
nzkiwivet's Avatar
nzkiwivet
got it sorted,took the battery out of wifes car and connected jumpers to the cables,opened the door and got it into neutral so I could push it into the shed.will get a new battery and get it checked over.thanks.
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
A spark will do it, that is why you should jump the car with the ground to the frame last and away from the battery.
Old Nov 13, 2016 | 07:16 AM
COMMANDER2OOO's Avatar
COMMANDER2OOO
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
I know this is what the experts say to do but grounding to the frame has never worked for me on any car I have ever owned.
Old Nov 13, 2016 | 08:30 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Very dangerous occurrence, glad you're ok. I also hope you gave everything in/around where the batt. exploded a very good washing.
Old Nov 13, 2016 | 09:10 AM
mracer's Avatar
mracer
Use baking soda to neutralize the acid, or you could be looking at some long term corrosion.
YMMV
Mike
Old Nov 13, 2016 | 11:14 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
YMMV
Mike
Very good point by Mike above!!! I just completed a short trip in my other car and early one morning I ckd under the hood. There was corrosion over the batt. holddown clamp. Cleaned it with water only. When I got home a week or so later, I looked and more corrosion, same place. Took it apart, used baking soda, then dried and put on some corrosion protector (vaseline).
Old Nov 13, 2016 | 12:26 PM
cclive's Avatar
cclive
This is a normal occurrence when the water in a battery gets low and the top of the plates is exposed to the air. When a heavy load is then put on the battery, like starting the car, a spark can jump across from plate to plate and ignite the hydrogen that is always inside the battery. Be sure to do alot of rinsing to get all the acid off the areas directly below the battery...lots of important wires and connectors there.
Old Nov 13, 2016 | 01:32 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Originally Posted by cclive
This is a normal occurrence when the water in a battery gets low...
And water will typically get low when a car sits for a while and then is driven and heavily charged...again, and again until the water "boils" out.
Hence the use of a maintainer.
Old Nov 13, 2016 | 07:46 PM
CadVette's Avatar
CadVette
Check over anything else on the car that may have caused a short. I'm thinking near the starter. Glad no major damage was done and it didn't blow up in your face or someone elses.
Old Nov 13, 2016 | 09:41 PM
Dave Tracy's Avatar
Dave Tracy
In an old Ford F150 the battery exploded. Very dangerous to get sulfuric acid (H2SO4 for you purists) on your skin or in your eyes. A classmate of mine had a battery explode in his face and he had acid burns for a couple weeks.
Old Nov 14, 2016 | 06:57 AM
BadAV's Avatar
BadAV
Yep, we had a 1992 Grand Caravan that did the same thing many years ago. Of course, it was when the wife was out of town on a trip. She shut it down, filled up with gas, and when she restarted the battery exploded. Luckily there was an auto parts store across the street so it was relatively painless for them to replace it. It appeared to me that the battery had run low on water, and between that and the high summer temperature, it probably shorted out with the current surge.
When she returned home I immediately sprayed the whole underside of the hood with baking soda/water mix. Never did have any paint or wiring issues so I guess it worked out OK. We drove that car for another 7 or 8 years after the explosion - we put right at 200k miles on it and only had routine maintenance in the 14-1/2 years we owned it.
To battery exploded!!
