Help. Wierd Issue
Old Nov 13, 2016 | 04:20 AM
Mohid Chaudhry's Avatar
Mohid Chaudhry
6th Gear
Default Help. Wierd Issue
i have a 2007 c6 z06 and with mcloed twin disc with tick master cylinder and i recently came through an issue, everything was normal started the car to warm up and suddenly after 10 mins car started to move forward itself. Shifter is in neutral but car wont go into gear seems like it is stuck in some gear. When i press the clutch paddle it stops to move forward and as soon as i start to release the paddle it starts to move forward. Any ideas what could be the issue that i need to check? Been replacing clutch oil time to time to avoid any mishaps. Urgent help would be appreciated. Thanks. Car has done only 16k miles.
